Page 2 of 2 FirstFirst 12
Results 41 to 43 of 43
Like Tree1Likes
Thread: Windows tinted WOOHOO and LED sidelight bulbs changed for better ones
  1. #41
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    I've never seen any, but you probably can somewhere.
  3. #42
    BahnStormer77's Avatar
    BahnStormer
    Feb 2009
    Surrey
    2,582
    Re: Windows tinted WOOHOO and LED sidelight bulbs changed for better ones
    Just don't be tempted with the "ice white" LED s. Mine passed three MOT tests with those at Audi, then failed at the local Indy. Not impressed!
    LostBok/BahnStormer77
  4. #43
    dpbayly's Avatar
    Oct 2012
    Royston, Herts
    368
    Quote Originally Posted by BahnStormer77 View Post
    What was there reason for failing with the white LED's
    Only reason I asked is my motor was tested last week at my garage and just by luck in the afternoon we had a VOSA spot inspection check where they pick a car that has been tested and re test it to check on the MOT tester to see if he has done his job correctly, mine was the only car on site that had been tested that day so he used mine to re test and the VOSA inspector said nothing about my white LED side lights and gave my car the all clear, so if he passes them the garage should definitely not have failed them????
  1. Recomendations for LED sidelight bulbs please.
    By Stepho in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 19th January 2010, 20:13
  2. Fitting LED sidelights bulbs leads to failure
    By heeman10 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th September 2009, 18:20
  3. Sidelight Bulb Change LED Style
    By cliveywolves in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th July 2008, 14:01
  4. Can anyone recomend a brighter or LED sidelight bulb I can buy now?!
    By Cossie_boy in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th February 2008, 12:11
  5. Cheap LED sidelight bulbs - not impressed.
    By Little_Si in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th November 2004, 09:46
