Chris NottAH Fabrications
Thread: Vcds results
    mattyb6's Avatar
    Apr 2012
    Tyne & wear
    437
    Vcds results
    Got my mate Paul26982 to scan my pd130 today, after a total boost fail the other night.
    the car basically went into limp mode, an acted like there was no turbo. Still drove just no power.
    next day it drove fine and has been since.
    paul scanned it today and these came up
    error codes :- 17994
    17965
    there were others but weren't related to engine
    1 17994/P1586/005510 - Engine Mount Solenoid Valves (N144/N145)
    this I haven't a clue about, so any help would be appreciated
    Secondly :- 17965/P1557/005463 - Charge Pressure Control
    i read on ross-tech this could be n75, boost leak, or sticky veins basically.
    i don't have a boost leak, and I know nothing about n75 valve. But my car has 165k
    should I consider the mr muscle on sticky veins?
    May 2012
    RETFORD, NOTTS
    1,753
    Did you clear them and see if they came back?
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
  1. Golf MKV Hot start problems - VCDS results
    By Ads_AudiA3 in forum Volkswagen and other VAG
    Last Post: 5th December 2012, 21:21
  2. South Central Meet Results + Logging Data from VCDS :)
    By vrbob in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th July 2012, 10:48
  3. VCDS results - can someone please check
    By Crazypete00 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd May 2012, 14:26
  4. TTC180 road test results anyone?
    By Mikiew in forum TT/TT-S/TT-RS Forum
    Last Post: 22nd June 2003, 20:51
  5. Rolling Road results
    By Simon in forum Major UK Events
    Last Post: 8th May 2003, 17:19
