Sky InsuranceAH Fabrications
Results 1 to 7 of 7
    Dec 2012
    Northants
    217
    What clutch do I need??
    After reading some very bad stories on line I've decided I'm going to order a clutch myself and have the local garage fit it.
    I will be ordering a Sachs clutch kit (no flywheel) off of ebay.
    Can someone post a link for the correcet one I need??
    02 1.8T sport.many thanks guys.
    If it's got tits or gears it's gonna be expensive.
    Dec 2012
    Northants
    217
    I've found this but I can only see BFB engine, mines AVF...
    Audi A4 B6 Saloon Sachs Clutch Kit Genuine Direct Replacement OE Quality New | eBay
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    538
    I cant confirm if thats the right one.
    But check if your garage will indeed fit a part you have supplied.
    My local wont do it as they cant guarantee the part is correct so cant guarantee the work..
    Andie0's Avatar
    Aug 2012
    487
    Are you standard power?
    2004 audi a4 s line 1.8t bex 242bhp dynoed
    Mods: bsr optiflow kit, forge diverter valve, custom turbo back exhaust, custom 200 cell cat, DGR coilovers, forge tip, s3/tt 386cc injectors, boost gauge, revo stage 2, 12mm rear spacers, rear window extension spoiler
    To come: big brake setup... Getting there!!
    boats and hoesss, boats and hoesss
    Dec 2012
    Northants
    217
    Quote Originally Posted by Andie0 View Post
    No mate, remapped to about 200bhp
    Andie0's Avatar
    Aug 2012
    487
    Oem should handle that then no problem! Didnt no if you was more bhp because i recall from previous post you said about your remap so was wondering if maybe you needed uprated clutch!
    Audi Doodah's Avatar
    Sep 2012
    Swindon
    371
    SACHS 3000 951 705 Clutch Kit
    XTend
    • Engine Code : AVF
    • to Ch.No. : 8E-5-040 000
    • Labour : 4,60 Hrs.
    • Diameter [mm]: 240
    • Number of Teeth: 23
    • Only install together
    • Only available as KIT
    • torsion damper clutch disc
    XTend
    • Engine Code : AVF
    Taken directly from Sachs' web catalog
    WebCat 3
    No AVF flywheel though. Also parts numbers for Lemforder suspension parts
  1. What clutch bits would I need?
    By zeeeebo in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th September 2009, 21:07
  2. cant decide what alloys to get need help
    By bigblokey0 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 9th July 2006, 14:03
  3. What Do I Do? Need Advice
    By A4Andy in forum General Chat
    Last Post: 17th June 2006, 13:39
  4. what clutch type do you have?
    By dummi in forum Tuning
    Last Post: 8th February 2006, 21:35
  5. What clutch?
    By imported_velcrobix in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th February 2005, 10:19
