EM TuningBadger5
Results 1 to 8 of 8
Thread: Egr leak
    mattyb6's Avatar
    Apr 2012
    Tyne & wear
    453
    Egr leak
    Would a leaking egr gasket cause really bad mpg on a 1.9 pd130?
    S3 GAZ's Avatar
    Dec 2006
    East Ayrshire Scotland
    347
    Re: Egr leak
    I have a leaking egr gasket on my 130pd quattro and get 42 - 44 mpg on dis.
    mattyb6's Avatar
    Apr 2012
    Tyne & wear
    453
    Quote Originally Posted by S3 GAZ View Post
    I think it's leaking, but in getting 20-35mpg, I know it needs a temp sender and stat.
    But don't know if anything else could cause poor mpmpg
    i used to get 55-60 easy last year
    S3 GAZ's Avatar
    Dec 2006
    347
    Re: Egr leak
    Stuck open stat will cause overfeuling if engine is not reaching operating temperature.
    Theres a good chance its this and not a dodgy temp sender. Was on mine
    Will cost £6 -10 for a new one and is relatively straight forward to change.
    Youl need some coolant to top up
    mattyb6's Avatar
    Apr 2012
    Tyne & wear
    453
    I'm mechanically ok, I'm going to replace stat and sender as they next to each other and both need coolant to be dropped. So be ride not to in my opinion
    S3 GAZ's Avatar
    Dec 2006
    347
    Re: Egr leak
    If looking at the engine from front of car. Stat is bottom right behind alternator. Temp sender is at back of engine infront of bulkead. Its under boost hose that goes into egr. Its a bit fiddly to get too.
    But may as well change them both if your dropping coolant out.
    mattyb6's Avatar
    Apr 2012
    Tyne & wear
    453
    I thought the sender was next to the stat, but it was at the bulkhead on 1.8t?
    either way I will look behind the egr.
    Thanks.
    Hopefully this will bring some mpg's back
    S3 GAZ's Avatar
    Dec 2006
    347
    Re: Egr leak
    No probs mate. Yeh different location on the 1.8 t
    Let us know how you get on.
  1. EGR leaking lots of oil - How to stop this?
    By scottshere in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th January 2012, 09:43
  2. Does your EGR leak on pd 130?
    By rob irl tdi in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th October 2011, 22:17
  3. EGR Leaking Oil
    Last Post: 18th September 2011, 00:25
  4. EGR leak
    By RyanA4 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 30th July 2009, 22:36
  5. oil leak from an EGR Valve and poor starting - related?
    By chill14 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th September 2008, 20:10
