Volks AutosEM Tuning
Results 1 to 8 of 8
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    538
    Oil leak from the oil filter housing.
    Chaps
    I recently changed the oil/oil filter.
    The filter and seal looked just like Genuine oil filter and seal VW Audi Skoda V6 diesel engines 059115562 | eBay
    The lid/top of the housing didnt have a seal before but I was supplied with one with the new filter so thought id use it.
    So I put that on where it seemed to fit IE around the outside.. I tightened it up but the seal kind of 'spodged' out 'a bit' so there was oil peshing down the side of the housing whilst the car was running.. I removed the seal and it seemed to be ok.
    After doing a hundred miles or so oil is coming out of the seal/gap of the lid/top of the housing..!
    What can I do to stop it? Did I use the gasket wrong before?
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    531
    When putting the housing back on,it should close (tighten) nice and smooth. If its hard and tight b4 its closed the seal is not sat properly
    1.9 avf 6 speed. Bv43 turbo. Swifttuning custom map. Powerflow straight through twin pipes. Allard delete kit. Boost,egt, + voltage gauges. Ball,spring boost controller. Fk silversport coilovers. B7 multifunc steering wheel. Full dis. Cruise control. Auto locks. Rs4 rear bumper. Full rs4 grills. Drls + hids. 10inch custom sub + amp. Leds everywhere
    Parrotkit full speaker streaming. silver 4d carbon interior.never ending...
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    538
    id say it tightens nice and smooth.. still leaks though..?
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    531
    Try it without the seal,if it didnt leak b4.
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    538
    Without a gasket is how im running at the oe, leak is less but still quite a leak!
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    538
    After a garage tidy last night I finally found my big adjustable so I could undo the oil filter housing cap.
    I had a fright as there wasnt a drop of oil in the filter housing!?
    First instinct was to check the oil level and its fine..
    The one thing that had happend was the filter was not clipped into the cap so I clipped this back in.
    On the cap I also found the old perished O ring. It was flat, rock hard and crumbled under my taking it off..
    I put my nice new round rubber O ring on and it appears to have fixed the leak!
    I am still concerened about no oil in the housing though!?
    Any advice?
    AlexGSi2000's Avatar
    Feb 2012
    Liverpool
    1,068
    Was there a little oil at the bottom of the filter housing? - the housings dont stay full of oil when the engine is off.
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    538
    I guess there was a drip..barely..
    I guess as i was used to a weeks previous when I done an oil change on a warm car it was full to the brim!
    If the oil drains out over night then im ok..
  1. Oil leaking from turbo down behind the engine....help!!
    By Wilts in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th July 2012, 19:43
  2. Oil leak from turbo oil feed. what gasket?
    By marshall-12 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th July 2012, 19:16
  3. oil leak from top of engine on the right hand side
    By harvey01 in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st January 2012, 20:45
  4. oil leak from an EGR Valve and poor starting - related?
    By chill14 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th September 2008, 20:10
  5. oil leak from turbo pipe
    By john24susan in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th February 2008, 09:57
