Volks AutosChris Nott
Results 1 to 7 of 7
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    606
    help vcsd needed near brighton. proper messed up car. :-(
    Earlier posts about removing cluster and back in.
    Well i removed bAttery to see if cleared things.
    Nope made things 10times worse.
    No cetral locking. Alarm wont turn off!!!!
    Battery flat.
    Lights flashing constently,locked but at least alarms not going on as well!
    So can anyone c me or il have to arrange towing to you. Cash waiting...
    A4 avant b6.1.9 avf 6 speed. Bv43 turbo.uprated fmic. KRAPtuning custom map. Powerflow straight through twin pipes. Allard delete kit. Boost,egt, + voltage gauges. Ball,spring boost controller. Fk silversport coilovers. 312mm brake upgrade. B7 multifunc steering wheel. Full dis. Cruise control. Auto locks. Rs4 rear bumper. Full rs4 grills. Drls + hids. 10inch custom sub + amp. Rear parking sensors. Leds everywhere. Parrotkit full speaker streaming. silver 4d carbon interior.never ending...
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    606
    While taking cluster out several times i happen to remember having ignition on while putting in-out!!!
    Still none the wiser
    going to check all plugs AGAIN tomoz.
    May 2012
    RETFORD, NOTTS
    1,748
    You said the alarm and locking was freaking out BEFORE removing the battery.
    Try pulling the dash fuses but recheck all the plugs/wiring.
    You mentioned fault codes, what were they?
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    Jul 2007
    London
    3,211
    Take the battery wires off and short the wiress using a spanner or similar. Do it on the wires from the car NOT THE BATTERY ! Also have someone turn the lights swich on to clear the static. If it still persists then you might need to clear the numerous fsult codes stored in the memor and see what comes back !
    FOR SALE:
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    606
    Quote Originally Posted by @udi A3 View Post
    You said the alarm and locking was freaking out BEFORE rem eoving the battery.
    i wrote them down il put them up later.
    The alarm went crazy after messing with the battery.
    pauldazzle's Avatar
    Cardiff
    621
    So when you removed the dash did you disconnect the battery first?
    A4 Avant B6 1.9 TDI 130 Sport (6) Moro Pearl Blue, GMBH S Line Kit, Decat, 165bhp remap, EGR delete, K&N panel, Dunlop SP Sport Max, Full Leather, Cruise Control, Full DIS, Bose, Audi phone prep, Cooled Glove Box, Rear privacy glass, Rear parking assist.
    2003 Seat Ibiza 1.2 TSI FR in Lima green.
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    606
    I didnt no. The how to didnt advise that.
    But with putting it back in,the ignition was on. Accident.
    I heard a fuzz noise when connected.
    Not touching the motor at the mo as the alarm goes off soon as keys go in or anyone goes in!
  1. Hi, help needed near Keighley
    By Mesa in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th October 2012, 21:12
  2. Help / Advice needed with part number
    By LeeW in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th February 2006, 23:16
  3. Help needed!!!!!!!!! Any idea what country these cars are from?
    By Markb in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th September 2005, 23:06
  4. Please HELP!!! Advice NEEDED!!!
    By AVerma in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th July 2003, 16:34
