help vcsd needed near brighton. proper messed up car. :-(
deano1978
different gear
near brighton
Earlier posts about removing cluster and back in.
Well i removed bAttery to see if cleared things.
Nope made things 10times worse.
No cetral locking. Alarm wont turn off!!!!
Battery flat.
Lights flashing constently,locked but at least alarms not going on as well!
So can anyone c me or il have to arrange towing to you. Cash waiting...
While taking cluster out several times i happen to remember having ignition on while putting in-out!!!
Still none the wiser
going to check all plugs AGAIN tomoz.
You said the alarm and locking was freaking out BEFORE removing the battery.
Try pulling the dash fuses but recheck all the plugs/wiring.
You mentioned fault codes, what were they?
Take the battery wires off and short the wiress using a spanner or similar. Do it on the wires from the car NOT THE BATTERY ! Also have someone turn the lights swich on to clear the static. If it still persists then you might need to clear the numerous fsult codes stored in the memor and see what comes back !
You said the alarm and locking was freaking out BEFORE rem eoving the battery.
i wrote them down il put them up later.
The alarm went crazy after messing with the battery.
I didnt no. The how to didnt advise that.
But with putting it back in,the ignition was on. Accident.
I heard a fuzz noise when connected.
Not touching the motor at the mo as the alarm goes off soon as keys go in or anyone goes in!
