AH FabricationsBadger5
Results 1 to 7 of 7
    crazypainter's Avatar
    Jun 2010
    Surrey
    587
    Reverse sensors stopped working?
    The reverse sensors seemed to have stopped working.....
    Had a look at the manual which lists all the fuses, fuse position 17 would be the one, but there would never have been a fuse there as it has no contacts. This fuse position is for amongst others, the parking aid.
    not sure what else I can check? I presume its a factory fitted parking aid I have, (Rear only) but dont know for def.
    Any advice please?
    Ta
    Need pinstriping? : www.crazypainter.com
    A4.. 1.8T.. Remapped .. Saloon.. Atlas Grey.. Votex Kit..
    Jun 2010
    Surrey
    587
    Should also add, there is also no beep when you first select reverse gear either.
    JasonS's Avatar
    Feb 2012
    North Herts
    90
    If its a factory fitted setup, VCDS scan should tell you what's up.
    But you should hear a beep, then continuous tone if one of the sensors has packed up.
    Mine packed up last year and have magically started working again.
    2005 A4 Sport Cabriolet 2.5 TDI
    Previous Audis:
    1997 A6 Avant 2.5 TDI Quattro
    1994 80 Cabriolet 2.0
    1995 S6 2.2t 20v Quattro
    1998 A6 Saloon 1.8t
    1995 A6 Saloon 2.0
    Jun 2010
    Surrey
    587
    Believe it or not, mine are fine again as well. In fact I went out about 10 minutes after posting my original post, and have spent the afternoon driving about to various places and its working as before.
    All good!!
    Feb 2013
    29
    how do you turn up the sound for parking sensors please
    Feb 2013
    29
    anyone help please
    JasonS's Avatar
    Feb 2012
    North Herts
    90
    With VCDS, you can turn up the volume
    http://wiki.ross-tech.com/wiki/index...nel_-_8E2/8E5)
    Previous Audis:
    1998 A6 Saloon 1.8t
    1995 A6 Saloon 2.0
  1. A3 8P reversing sensors not working.
    By Vorshprungdork in forum General Automotive Chat
    Last Post: 31st January 2013, 14:14
  2. Aftermarket Audi Reverse parking sensors stopped working, help please?
    By Bailey in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th August 2012, 20:28
  3. Reverse sensors stopped working?
    By boya in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd April 2011, 12:04
  4. Replies: 3
    Last Post: 12th February 2011, 09:56
  5. Headlights stopped working
    By skipper316 in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th October 2003, 16:26
