EM TuningMonster Motorsport
Results 1 to 12 of 12
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    530
    safe mode???????????
    Took my cluster out to clean,full of dust.
    On putting back. Mileage reads fuse then safe and also wont start....arrrrhhhhh.
    A4 130 b6 avant sport avf engine...expert tuning remap...direct cold air intake mod...pipercross panel air filter...Egr delete and mapped out...decatted...19" vertin concave alloys...boost controller...dual powerflow exhausts...rear full privacy shades...led upgraded bulbs (inside + out)...6000k drls+ hids...debadged...custom front splitter...Fk highsport coilovers...Custom rear sub install...cruise control retrofit...DIS retrofit...rs4 rear valance...Full rs4 style grills (front)
    dpbayly's Avatar
    Oct 2012
    Royston, Herts
    366
    I take it you have tried unplugging and plugging back in, in case there's a bad connection?
    Jun 2003
    World of my own
    9,813
    Need to check fuses sounds like you've blown one
    Alex Turner
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,910
    as above check fuse
    then check its plugged in right.
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    530
    Im putting hand through the side by fuse box and wriggling. Lights gone on and off if wriggled hard. But keeps coming back on to safe mode where the mileage reads? Not saying fuse no more?
    Turns over but just cuts out?
    bez101's Avatar
    Jul 2008
    7,910
    take them back out and refit plugs
    dpbayly's Avatar
    Oct 2012
    Royston, Herts
    366
    Check one of the tiny pins on the back of the cluster haven't bent over and is missing the hole in the plug easily done if not careful
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    530
    Will do. should also mention that the coil is flashing and handbrake as well as no lights working
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    530
    No good all looks good. Getting a code 00474
    cluster light up but not properly. As in ngt time
    dpbayly's Avatar
    Oct 2012
    Royston, Herts
    366
    Did you dismantle the cluster to clean or just remove?
    dpbayly's Avatar
    Oct 2012
    Royston, Herts
    366
    That codes is
    00474 - Control Module for Immobilizer
    Sounds like its a communication problem with the cluster for sure
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    530
    Nightmare for sure
    18056 missing drive train comms
    18043 ac fuse
    17978 immobilzer
    18062 colant temp
    All this in aid of abit of dust to clean inside cluster. And followed a how to.
    I dont no where to start :-(
  1. Replies: 2
    Last Post: 10th April 2007, 18:13
  2. Concert "safe" mode help
    By Rick in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th December 2006, 20:02
  3. Audi concert stereo safe mode! Help!!
    By petephoenix in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th November 2006, 19:32
  4. Arggghh RADIO showing SAFE mode!!
    By JB_A3_Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th August 2006, 21:11
  5. radio in safe mode , label help
    By Jonny_doe in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th February 2005, 08:55
