Volks AutosEM Tuning
    Apr 2012
    Ayrshire, Scotland
    20
    A4 1.9 Quattro Drivers window,drivers demist and both mirror adjustment not working.
    Hi
    The other day the wife went put the divers window down, it got part way and stopped. After playing with the button a few times, it went up a bit and then stopped. Now dead. The other 3 windows work fine form the drivers door.
    The adjuster for the mirrors does not work for either window.
    The demist on the drivers mirror does not appear to be working but the passenger side appears to be working.
    Changed the right / left door fuses over - no change
    Replaced the window motor complete with the attached "black box" - no change.
    Is there a main feed that supplies power for the door components via relays and a separate feed to the switches?
    Before I rip the loom apart at the door boot looking for broken wires, any thoughts?
    kite's Avatar
    Oct 2007
    East Berks
    659
    Check the loom between the door and the A pillar. The loom is known to break there.
    A4 (b6) 2.5 TDi QS Saloon.
    Apr 2012
    Ayrshire, Scotland
    20
    Yep, going to dive into that tomorrow. What ever happened to German quality engineering?
  1. A4 Quattro (2005) Drivers Window
    By Rob Hill in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 19th July 2010, 18:42
  2. drivers window/door 'creak'
    By imported_CurryMilkShake in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 30th October 2007, 13:21
  3. closing of drivers window (help)
    By Vikz in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th August 2006, 23:53
  4. rain = drivers window problem...
    By Pete69zx in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th August 2006, 20:39
  5. My drivers window isnt going up properly?????????
    By BromleyA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th June 2005, 15:44
