Results 1 to 12 of 12
    czm
    Feb 2013
    216
    Crankcase Breather Valve
    I have purchased a new crank case breather valve from Audi and am going to fit howewver it looks a real pain to get to the old one, Anybody got any tips?
    Also is there a good chance that something else might break whilr i am doing it? ie brittle pipes ect
    2004 BEX 1.8T Silver Avant - RTECH Stage 1 Remap - 211Bhp/236ft Torque
    TEIN Super Street Coilovers - BlueFlame Catback with 4'' Slashed/Rolled Tips
    Pipercross AirFilter- RS6 18'' OEM's - 225.35.15 Falken 452
    Jun 2011
    130
    Not sure what motor you have mate, but ive just done mine on a 3.0 a4
    Simply lift to plastic retaining clips on valve with flathead screwdriver, not to rough as there not that strong, then pull forward valve to break seal, then twist upwards again not to rough from bottom breather pipe, it then pops out, give breathers a bit of a wipe, lube up your new one and pop it in,
    Bottom first into breather, make sure nice and sealed then clip in to the two retaining clips at side
    Job done !!!
    czm
    Feb 2013
    216
    lol Sorry forgot that part..its a 1.8t avant 2004.
    i found this but i am still finding it difficult to get to.
    Crankcase Breather Valve Location
    Jun 2011
    130
    Ignore my advice then mate !
    Jun 2011
    130
    Although yours looks a lot easier than mine ,,
    czm
    Feb 2013
    216
    Im still confused how you are meant to get to it????
    Mar 2012
    188
    Pain in the backside. Did mine today whilst cleaning all the breather pipes. The rubber pipe it sits in is a paint to get off the metal pipe to the back of the engine bay. I bought a new pipe and just cut it off. Wish I'd also bought a new one that goes from this pipe to the oil filter housing. Mine just crumbled once I got it off so the car is off the road until I get hold of a new one.
    My top tip is detach the coolant reservoir and lift out of the way.
    Dubbers1's Avatar
    Top Gear
    Jul 2011
    Bedfordshire
    228
    I did mine a few weeks ago
    Flip the coolant reservoir up out of the way then you can take the one use clip off the valve and it'll just slide out, replace the new valve and put a new jubilee clip on it
    Took me 10 mins tops
    Dont know why you would need to take the pipe off the other side of it
    Audi A4 1.8T S-Line Quattro (190) '04
    VCDS HEX-USB+CAN
    czm
    Feb 2013
    216
    Quote Originally Posted by Dubbers1 View Post
    Thanks m8.
    can I confirm it is the pipe that is going into the T shape part. It looks like I have to undo a unscrew jubilee clip?????
    Mar 2012
    188
    Because I was cleaning out the breather system. If you got crap in the breather valve it's likely you've got crap elsewhere in the pipes.
    Dubbers1's Avatar
    Top Gear
    Jul 2011
    Bedfordshire
    228
    Yes it does go in to a T-shape part, this part is not commonly replaced due to being gunked up, they collapse like this
    Here's the valve, number 6 (just realised this is for the wrong engine code but this part is the same, just the top end is different)
    VCDS HEX-USB+CAN
    Mar 2012
    188
    [/QUOTE]
    Which is the entire system that I have cleaned out and degunked.
    Part 17 was pretty much blocked with hard gunk. The rest of the system was pretty bad as well but not with solid stuff, just very thick oily smeg.
    I've also had the pick up pipe replaced and the sump cleaned out. Next on my list is the turbo oil feed pipe. And this is all on a 104k mile car that was on long life servicing for the first three years of its life. Oil replaced with fully synthetic every 7.5k miles after that.
  1. Crankcase Breather Valve Location
    By CHRIS555 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th August 2013, 21:46
  2. Replies: 37
    Last Post: 31st March 2013, 19:15
  3. Where to buy a crankcase breather valve for 1.8t
    By duffy78 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd February 2013, 07:55
  4. crankcase breather valve thingy, part number?
    By hitman1978 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th July 2012, 22:54
  5. 2.5TDI crankcase breather
    By Graze in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th October 2005, 17:32
