Badger5Monster Motorsport
Results 1 to 8 of 8
Thread: help needed
    cabby's Avatar
    2.4 V6 sound
    Nov 2010
    south lincs
    78
    help needed
    Turns over but won't fire up.half a tank of petrol, Fuses all ok, no fault codes, put jump leads on and still nothing, no smell of petrol after! Checked plugs and were bone dry. Any feed back would be appreciated.
    Mar 2008
    1,057
    Can you here the fuel pump prime????
    cabby's Avatar
    2.4 V6 sound
    Nov 2010
    south lincs
    78
    No. Just a faint tiny click!
    Mar 2008
    1,057
    Fuel pump maybe ????
    cabby's Avatar
    2.4 V6 sound
    Nov 2010
    south lincs
    78
    I've been on u tube this afternoon and the fuel relay was mentioned as a possible problem. Just taken the cover off in the boot and looked at the pump housing!!!! Not to sure how that comes out.
    cabby's Avatar
    2.4 V6 sound
    Nov 2010
    south lincs
    78
    Lovely motor, not a lot of good when it don't work!
    And the sun is coming out...
    dpbayly's Avatar
    Oct 2012
    Royston, Herts
    368
    With the cover off when you turn the ignition on do you hear the fuel pump fire up?
    If so i would be looking at the crank sensor as the injectors wont fire if there is no signal from the sensor, sometimes if the sensor fails it wont give off a code if it has failed since it was last run, it would only throw up the code if it fails while the engine is running
    cabby's Avatar
    2.4 V6 sound
    Nov 2010
    south lincs
    78
    Thanks for your replies, that's one more thing to check. Got a guy coming to look at the car this week, so i'll update progress and maybe the info will help others.
  1. Help needed again.
    By Stuart_A3_Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th July 2003, 22:12
  2. Urgent help needed
    Last Post: 13th July 2003, 09:02
  3. Help...need to order
    By Drystone in forum Detailing
    Last Post: 4th June 2003, 23:39
  4. Replies: 0
    Last Post: 1st March 2003, 19:50
  5. Help! Need a new coilpack!
    By SteveS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd January 2003, 22:29
