AH FabricationsJMB Retrofits
Results 1 to 9 of 9
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    625
    tractor like sound on idle
    Sounds like something rattling,loose like tractor sort of noise.
    It only happens on idle. When revved it goes away.
    Ive looked under the hood and the sound is coming from alternaor fan belt thingy.
    Whats on its way out??? Any ideas? alternator pulley was done 3 months ago
    A4 avant b6.1.9 avf 6 speed. Bv43 turbo.uprated fmic. More bhp custom map. Powerflow straight through twin pipes. Allard delete kit. Boost,egt, + voltage gauges. Ball,spring boost controller. Fk silversport coilovers. 312mm brake upgrade. B7 multifunc steering wheel. Full dis. Cruise control. Auto locks. Rs4 rear bumper. Full rs4 grills. Drls + hids. 10inch custom sub + amp. Rear parking sensors. Leds everywhere. Parrotkit full speaker streaming. silver 4d carbon interior.never ending...
    Feb 2011
    Ireland
    41
    Sounds like the clutch in the alternator pulley
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    625
    Thanks for reply.
    New to me.. Clutch pulley?
    Cld you tell me more?
    Big fix?
    Ok to drive?
    Please.
    Goint to take it garage tomoz.
    Oct 2009
    Hull
    1,440
    the alternator has a clutch pulley to allow it to turn freely when starting to reduce the load once its running the pulley is engaged so the alternator spins up
    not sure how easy it is to change though
    It could also be the air con pulley rattling if the buffers in the pulley are worn to check that simply hit the econ button on the climate while you have the window wound down and it will get louder if it is that
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    625
    Cld it really be clutch pulley again.
    Iv just messed around with ac and econ. No different!.
    Garage it is.
    Mind you,if it is pulley,should be covered as its only just been done.
    Feb 2011
    Ireland
    41
    the clutch pulley will cost something around £30. You need a special tool to remove the pulley. Check out youtube alternator clutch replacement for a demo on how to.
    pauldazzle's Avatar
    Cardiff
    634
    Switch the Econ button on & off with bonnet open. If it has an effect on the rattle the AC compressor pulley is goosed.
    A4 Avant B6 1.9 TDI 130 Sport (6) Moro Pearl Blue, GMBH S Line Kit, Decat, 165bhp remap, EGR delete, K&N panel, Dunlop SP Sport Max, Full Leather, Cruise Control, Full DIS, Bose, Audi phone prep, Cooled Glove Box, Rear privacy glass, Rear parking assist.
    2003 Seat Ibiza 1.2 TSI FR in Lima green.
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    625
    Thanks but tried it last ngt with no difference.
    Off to garage now.....
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    625
    Just been my local garage and there baffeled?
    They come to the conclusion its the ac pump. Not a cheap fix.
    But i have a warrenty with motor thats soon to run out. Lets hope im covered.
    Part is £260 inc vat + labour
  1. Replies: 3
    Last Post: 13th April 2014, 23:30
  2. Still lacking power and sounds like an old tractor! 1.9tdi aaarg!! Help!
    By skinflint in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd February 2013, 09:24
  3. Audi S3 8P rackety/tappet/diesel sound on idle
    By AntonTDI in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th January 2013, 19:24
  4. few issues... draining battery, lumpy idleand sounds like a tractor
    By hannakournikova in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd November 2008, 10:27
  5. Knocking sound on idle???
    By Platinum70 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd June 2006, 14:49
