AH FabricationsSky Insurance
    Oct 2011
    Central Locking woes
    Hi all im after some help if possible.
    Ive had my b6 over a year now and the key i had has always been tempremental, If I put a new a battery in the fob and resync it with the car all is fine for a week or two then the fob starts unbonding from the car it will resync several times then it stops, with a new battery this will be repeated. i assumed the key was eating batteries so ive had an autolocksmith out to cut and recode a key. He couldnt gain access to the part of the cars ecu that controls the remote slots as it was coming up in German instead of English! Ive checked the wiring between the doors and pillars they are fine.
    How do I inspect the convenience unit etc is there anything else I can check.
    Oct 2009
    Hull
    1,440
    Its more then likely your fob
    over time they work loose and the battery pins can lose contact with the battery
    open the fob and bend all the pins so you have a better contact and see if it works it sorted mine out and a few others on here
    Oct 2011
    Its not the fob mate, he tested it with some gadget and the new one wont code in
    Oct 2009
    Hull
    1,440
    like I said over time the fob come loose (the plastic casing) and the battery can lose contact causing it to need resyncing again
    just because its been tested doesnt mean you have a good connection on at the terminals it could just have been working fine at the time!
    just think what a key goes through during 1 day of been in your pocket all you need is for it to flex a bit and the battery lose contact with the pins and it will need to be synced again
    mine used to do it all the time sometimes it would go weeks then others a matter of hours if not minutes
    I bent the pins and for over 2 years its been spot on
    try it its free and only takes a few minutes
    Oct 2011
    Its not the fob mate it was tested, a new battery was put it in its resynced again, the locksmith couldnt gain access to the coding section of the ecu as it appeared to be corrupt and coming up in german and chinese symbols. This meant the new key couldnt be programmed in to the ecu, it now starts the car etc but it wont operate the central locking etc
  1. Central Locking Woes - Urgent Fix Required!
    By LoopTrooper in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd August 2012, 21:58
  2. More Central Locking Woes, Damn You Audi!
    Last Post: 17th August 2012, 08:58
  3. Central locking woes
    By theviking in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd February 2010, 17:05
  4. Central locking woes!!
    By stu_m in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th December 2009, 16:27
  5. More tailgate woes... Central locking not working.
    By amimmortal in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 29th November 2009, 20:29
