Chris NottSky Insurance
Results 1 to 18 of 18
    Jan 2013
    Northern Ireland
    71
    Windows going down on their own
    Hey all, new problem again, when I open the RCL on the car my windows roll down, normally you have to hold the button in but it's just an unlock. I've checked the ccm and its as dry as snuff nod all wire appear to be ok. Anyone got any clues?
    Jan 2013
    Northern Ireland
    71
    Also noticed the doors keep unlocking or trying to unlock when your driving along. Anyone got any ideas?
    kite's Avatar
    Oct 2007
    East Berks
    660
    Re: Windows going down on their own
    Scan for faults. ..
    A4 (b6) 2.5 TDi QS Saloon.
    Oct 2009
    Hull
    1,433
    I was going to say remote problem but the remote shouldnt operate the doors when the car is running
    4th set of a wheels in a year
    Jul 2012
    merthyr, south wales
    425
    Visit krisavant's Instagram Channel
    Sticky key lock?? Maybe..
    Even though you use the key remote to unlock the car, the manual key lock can get full of gunk and cause the issues your having.
    Obviously better to completely remove the lock and clean it out but if you can't get some wd40 in the lock using the key to free it up.
    Had this happen to me twice on vag cars.
    scottshere's Avatar
    Dec 2010
    South Yorkshire
    337
    Wiring issue to the drivers door?
    A4 1.9TDI Sport - 130 (B6) / Mods: None yet, just getting the basic right first
    Blackie's Avatar
    Feb 2004
    In a house
    634
    Broken wire in the door hose
    Mine did it and sent the windows & locks haywire. It was the big brown one & i pulled the boot back enough to solder & piece of wire in & shrinkwrap it. After that it was all good
    Jan 2013
    Northern Ireland
    71
    Thanks for the replys guys, I read the computer today and got a shopping list, so i cleared them and these kept popping up every time for the CCM or CCU as some call it.
    2 Faults Found:
    01134 - Alarm Horn (H12)
    49-00 - No Communications
    01031 - Central Locking Key Switch; Driver Side; Unlock
    27-00 - Implausible Signal
    Make any sence to any one?
    Oct 2009
    Hull
    1,433
    going by that you have either a busted lock or a broken wire
    check the wiring first as its easy and free
    Jan 2013
    Northern Ireland
    71
    Check in the black tubing going from the chassis to the door? or where else?
    Oct 2009
    Hull
    1,433
    Yeah peel back the rubber boot and have a look its a bit fiddly also pull the connector block off there is a tab you push in on the opposite side I had broken wires and corroded pins and 2 pins had snapped off
    use a mirror and a torch to check the pins in the connector if you cant see anything on the wiring you may have to take the door card off and release the cable so you can pull it through more most of the time you can see it though
    Jan 2013
    Northern Ireland
    71
    Peeled back the rubber and there's a plastic clip. At each side. Can only look at wires from chassis side of car as other side is wrapped with something. Tried to put all back but the rubber won't go back on and the clips won't either. Cant see any broken wires at chassis side. Don't know what do do next.
    Jan 2013
    Northern Ireland
    71
    Little update guys, seems like you all were right, the wires were broken, took loom out eventually, not without breaking the clip that goes into the chassis but however. Repaired the cables, but will replace the cables next time completely instead of cutting the bad bit out and replacing as it will be much neater. Thanks for the heads up anyhow guys, will do a read in vag com next to see if that cured the problem there.
    Jan 2013
    Northern Ireland
    71
    Further update guys, this didnt fix the problem, I only thought it did as it didnt do it that evening, it still does it. What next to check?
    Jul 2012
    425
    I still say sticky key lock mechanism.
    Jan 2013
    Northern Ireland
    71
    I have a feeling your right, when using the key only sometimes it locks and unlocks the car. Would that mean the full would need replaced?
    Jul 2012
    425
    No need to replace anything.
    Just take the lock barrel out, give it a good clean with wd40, regrease then put back in.
    Jan 2013
    Northern Ireland
    71
    That can be taken out with the 1 screw from the side yes?
  1. Windows not going down
    By AlexGSi2000 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th June 2012, 21:42
  2. Windows opening on their own!?!
    By daver555 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st August 2011, 13:32
  3. Drivers Side Window - Not Going Down With The One Touch
    By silversurfer in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th April 2010, 10:12
  4. Passenger Window Keeps Going Down! Help!
    By emzino in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd July 2008, 01:52
  5. Passenger window found down !!
    By impmad in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th October 2003, 20:04
