Sky InsuranceJMB Retrofits
    Jul 2010
    184
    Viscous Fan and Coolant Temp
    Somehow my viscous fan has been totalled, about 2/3 of the blades have been smashed off, resulting in putting a hole in my rad. Gutted.
    For a fix to get me back on the road i've left the viscous fan on, albeit in a state, and chucked some rad weld in to stop the leak. All seems fine now.
    What ive noticed now is my coolant temp takes an ages to hit 90 then drops when cruising or when i run the heaters, is this due to my dodgy viscous fan or coincidence that my 18 month old stat is failing?
    I'll probably replace all three anyway but was just curious.
    Also, anyone have a part number for the rad and viscous fan blade?
    Thanks.
    White A4 B6 Avant 130 Sport
    Jun 2011
    Great Melton Norfolk
    1,349
    Was the stat a genuine one , if not make sure you use a genuine one when you replace it.
    pauldazzle's Avatar
    Cardiff
    637
    You need to get the radweld out quick, it's probably caused the stat to stick open. Radweld really is a get you home fix.
    A4 Avant B6 1.9 TDI 130 Sport (6) Moro Pearl Blue, GMBH S Line Kit, Decat, 165bhp remap, EGR delete, K&N panel, Dunlop SP Sport Max, Full Leather, Cruise Control, Full DIS, Bose, Audi phone prep, Cooled Glove Box, Rear privacy glass, Rear parking assist.
    2003 Seat Ibiza 1.2 TSI FR in Lima green.
  1. Oil temp and Coolant temp gauges not working.
    By jgttdi in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th February 2013, 13:55
  2. 2.8 V6 viscous fan and slight thudding noise
    By S4_dan in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th June 2011, 00:09
  3. broken viscous fan and now RADIATOR! really???
    By TeKnodriver in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th June 2011, 10:38
  4. Air Mass Meter and Coolant Temp. Sensor
    By nu boy in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th April 2008, 20:29
  5. Engine Coolant temp and Lambda sensor
    By taj in forum TT/TT-S/TT-RS Forum
    Last Post: 9th March 2005, 13:05
