JMB RetrofitsEM Tuning
    Mar 2004
    Flebible Hose Connections......
    Going to look at replacing a coolant flange but looking at some of the flexible rubber hoses, i dont recognise the clamps used....
    Are these one shot items.........
    Mar 2012
    188
    Yeah unfortunately typically a one shot deal. They can be clipped back together but not with the same tension.
    I cleaned all my breather pipes out last weekend and replaced with jubilee clips. They are cheap enough that its not an issue.
    Mar 2004
    Quote Originally Posted by duffy78 View Post
    How do you get the little beggers off......
    Mar 2012
    188
    Small flathead screw driver under the lip and twist. They are tension clips so once you lift this section they tend to ping open.
    Ollie-B's Avatar
    Rockin' Shnit
    Dec 2012
    Stanley, North East, UK
    292
    Someone needs to change this title im creased laughing at it hahaha
    blacksmoke remap, 18" alloys, coilovers, heko wind deflectors, c/coded door blades, DIS, Cruise, votex front grille
    TO DO: fit my votex front valance (in the shed), c/code the rest of the lowers, sport interior
  1. EGR valve hose connection
    By crazy88 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 13th January 2013, 10:14
  2. Quick connect heater matrix hose
    By NineNails in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd November 2012, 22:29
  3. Not connected hose on an AGU 20VT
    By Lazaros in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st April 2012, 02:06
  4. Perished hose connecting to inlet manifold
    By barters3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th December 2009, 23:12
  5. Charcoal Filter Solenoid Hose connection
    By waveform2 in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th November 2007, 21:38
