    Oct 2010
    metal on metal clunk sound on slow maneuvering
    Hi all, i've been having a fairly subtle metal on metal sound coming from somewhere.. can't pinpoint it as it only happens when moving and the mrs doesn't drive. I thought it might be the bushes excessivly worn and have change the front drop links, arb bushes and bottom end and it's still the same. I don't have access to anything other than a couple of axle stands and ramps so getting a good look under the car is very difficult.
    any suggestions would be appreciated, thanks
    Alan H's Avatar
    Need a V8 or Bi-Turbo.......
    Aug 2010
    Dudley, West Midlands
    453
    Could be a gearbox mount..
    Oct 2010
    how would i check if the mounts are ok? just a case of giving the gearbox a good wiggle and see if it seems excessivly loose?
    2004 Audi A4 2.5 Tdi Quattro Sport trip
    Alan H's Avatar
    Aug 2010
    453
    It's usually the gearbox cradle one that's gone, the one that sells for about a ton on good old bay of the e. It really needs to go on a ramp to confirm though I would suspect. Someone else may no of an easier way to check though.
    marktdisport's Avatar
    Jul 2011
    mids
    1,193
    My rear gearbox mount disintegrated causing a heavy knock which could be felt by your left foot area of the gearbox tunnel
    A4 TDI 130 SPORT..
    now sold but still in the family, gone back in time to the cupra R again..
    Dubbers1's Avatar
    Top Gear
    Jul 2011
    Bedfordshire
    228
    I had a knock like this a while back and turned out to be the front drop links, only £15 on ebay for a pair with new bolts
    Just had a knocking when parking and turning the wheel while moving slow
    Audi A4 1.8T S-Line Quattro (190) '04
    VCDS HEX-USB+CAN
  1. clunk clunk sounds in my 2.5TDi :( - Tensioner??
    By dhillon884 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th June 2010, 21:41
  2. CLUNKING SOUND FROM PASS WHEEL SIDE?????
    By E4 FENN in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th January 2010, 18:42
  3. Clunking sound!
    By nickelvery in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th July 2007, 18:23
  4. metal on metal sound and rear wheel wobble
    By ScoobyA4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th April 2007, 00:36
  5. creaking / clunking sound (offside front) when turning right ?
    By LeeW in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th April 2005, 22:38
