EM TuningJMB Retrofits
Results 1 to 27 of 27
    Feb 2013
    33
    HIDs fitting help
    Hi guys
    Im due to pick up my new A4 1.8T s line cab next week and would like some help fitting a HID kit (im not mechanically minded at all). Im in the leicester city area and would appreciate any help.
    Also, the glove box in this car is broke/loose - is it easy to fix/replace?
    thanks
    Sublime
    AlexGSi2000's Avatar
    Feb 2012
    Liverpool
    1,145
    The HID kits nowadays are really easy to fit.
    The most technical part is drilling the hole on the bulb cover at the rear.
    If you were closer I would have sorted it for you.
    2002 A4 Avant Quattro Sport 2.5 V6 TDi - 219Bhp - Votex
    BCS Automotive Turbo-Back - Remap -
    19" RS6 Reps - B6 S4 Brakes - Symphony II+
    - Weitec GT
    - 2001 Honda CBR600-FS1 -
    Feb 2013
    33
    Alex
    thanks for the reply - do I have to take the bumper off on the 2005 model?
    and silly question but why the need to drill the hole?
    Also, Im thinkin of getting these -
    H7 ULTRA 35W SLIM CANBUS HID XENON CONVERSION KIT - HIDS DIRECT LTD Store
    would they be ok?
    thanks
    Feb 2012
    Liverpool
    1,145
    Im not sure if the cab is different to the normal A4 in regards to removing the headlights?
    When I removed the headlight to fit my HID kit on my avant I didnt have to remove the bumper.
    You will need to drill the hole to get the cables too and from the ballast / bulb- most new kits come with grommets so it will seal the hole once the cables are through.
    I got the canbus pro kit from HID direct but the slim kit will be fine.
    - Weitec GT
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    There are a couple of threads in the DIY guide sticky about glovebox repairs. there is also one about fitting HID's I think.
    Headlight removal in the cabby was discussed a couple of weeks ago, from memory its the same principle as the other models, except there's only the one screw underneath to undo rather than two. I don't think you need to remover the bumper, but hopefully someone can confirm.
    Feb 2013
    33
    quattroJames thanks for the reply. just a shame youre down in dorset
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,423
    you have the B7 cab (2005) ?
    to remove the lights is a bumper off job
    unlike the B6
    the hids can be fitted with the lights on the car but it is very tight to do
    but doable
    but for a neat job with the ballast hidden the bumper needs to come off.
    Feb 2013
    33
    bez
    i have the B6 chassis ( i think) its registerd 04/2005 -
    i think I will just pay if I have to take the bumper off - Im really no good with all this car stuff
    Rudedaubin's Avatar
    Oct 2011
    South Yorkshire
    70
    You definately don't need to take the bumper off, I removed my headlights yesterday. 2 torx bolts on the top need removing, 1 torx bolt on the bottom needs loosening and the wiring clip needs unclipping. The light will then slide forward and out although it does take a little bit of wiggling. I would put some masking tape along the top of the bumper too just to stop any scratches.
    2004 A4 Sport Cabriolet 3.0
    Feb 2013
    33
    Rude
    thanks. Did you need to drill a hole in the back of the light cover? Wher did you fit the ballasts?
    Fancy helpin me with mine If i drive to south yorks
    bez101's Avatar
    Jul 2008
    8,423
    if it is B6 then its very easy to remove lights
    big grill or small grill ?
    Rudedaubin's Avatar
    Oct 2011
    South Yorkshire
    70
    Haha, I was lucky , mines got factory fitted HID's. The ballasts are mounted to the inside edge of casings. I'm just trying to find some pics to show you. I'll gladly help but it's quite a drive for 2 holes lol.
    Rudedaubin's Avatar
    Oct 2011
    South Yorkshire
    70
    Bez I think B6 cabs went right up to a 55 plate and the first B7's were 06's although I'm not 100%
    Feb 2013
    33
    bez101's Avatar
    Jul 2008
    8,423
    easy then its really a hours job thats with a cuppa thrown in
    Feb 2013
    33
    rude
    ive driven further for 1 hole
    where abouts r ya? from me sheffield is abt an hour away - plus it wud b nice to see what the cars like on't motorway
    bez101's Avatar
    Jul 2008
    8,423
    im in sheffield but busy till after the weekend
    bez101's Avatar
    Jul 2008
    8,423
    or ill be around tamworth services on sat after 12
    that must be closer than sheffield to you ?
    Feb 2013
    33
    bez
    i was thinkn more next weekend (2nd march sat pm) if your free and weather permitting?
    Feb 2013
    33
    its about the same tbh 1hr - besides nt free this weekend...
    bez101's Avatar
    Jul 2008
    8,423
    every weekend i travel from sheff to south wales
    so if you could get to tamworth id be happy to help
    Feb 2013
    33
    oh ok - sounds good. i will PM you to confirm nx wk mate.. if you dont hear from me - it means I;ve picked up the courage and hav a go myself
    Rudedaubin's Avatar
    Oct 2011
    South Yorkshire
    70
    I'm just about 10 miles north of Rotherham , and will certainly help out if you need it. I think I've got the removal of mine down to about 5 minutes for both sides :-) This was yesterday!
    Just be aware as I'm not sure if the halogens have the plastic reflectors, and I've had a real issue with burnt reflector bowls from the heat that the HID's produce.
    Feb 2013
    33
    rude
    5 mins is impressive... as i sed to bez- im free next weekend and will give it a go nxt wk - if i get stuck i let you know and drive down if u free on the 2nd?
    hw far from sheffield r you?
    Feb 2013
    33
    this is the kit im going for:
    H7 Canbus Pro HID Conversion 35w kit - HIDS DIRECT LTD Store
    torn between 4300k ot 6000k
    Rudedaubin's Avatar
    Oct 2011
    South Yorkshire
    70
    Sheffields about half an hour from me, maybe 15-20 miles. I've never fitted one of the aftermarket kits but I've got 4300k philips lamps in mine and they're blue enough for me.
  28. #27
    Mar 2008
    Dorset
    13,856
    Quote Originally Posted by sublime View Post
    As I said earlier, all the questions you're asking are in the DIY guide sticky, which is designed to HELP people....!
    Hid kit - Diy guide for the b6
    Retrofitting Valeo HID Xenons to H7 Headlight
    Slimline HID Ballasts -now fitted in Headlight
  1. HID fitting - help required
    By jbcalvin in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th February 2011, 19:30
  2. IC hose fitting (help)
    By scib4 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd March 2007, 01:04
  3. S-line rear bumper fitting help!!!!!!!!!!!!!!!!!!!!
    By Arf in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th March 2006, 10:37
  4. Side repeaters - fitting help!!
    By marcus7 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th June 2005, 17:18
  5. New Wheels, don't fit, HELP!!
    By danjones in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th April 2005, 16:06
