Volks AutosMonster Motorsport
    Nov 2012
    sunderland
    73
    Audi a4 2.5 tdi Quattro starting problems
    Not long bought my Audi a4 tdi Quattro it's a 51 plate was running fine for weeks, come out the house 1 zday and just would not start, put it on vag and said crank shaft sensor so changed that and still no start the only way it will start is with easy start a mean once its started its spot on runs like a dream when it's starting as we'll it kicks out a lot of smoke but soon as it starts that clears any ideas any1 please.
    Feb 2013
    It will often throw that code if its cranking but not starting, doesnt always mean its the sensor itself.
    If it starts with easy start then its either lack of fuel, or some/all glow plugs arent getting hot enough.
    If you have Vag-Com (VCDS) what does it say for coolant temperature in measuring blocks before you try and start it?
  1. 2007 Audi A3 170 TDI Quattro idle problem? Injector Recall done.
    By davsmith64 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th July 2013, 12:14
  2. 2.8 quattro starting problem
    By cobes1981 in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th August 2008, 11:10
  3. Buying Audi A4 2.5 TDI Quattro
    By gc2318 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd December 2006, 08:48
  4. audi coupe 2.3 e cold start problems
    By buzby3xx in forum Classic Audi Forum
    Last Post: 27th August 2006, 23:21
  5. AUDI 80 TDI 1995 starting problems
    By adidasandy in forum Diesel forum
    Last Post: 6th June 2006, 13:01
