JMB RetrofitsChris Nott
Page 2 of 4 FirstFirst 1234 LastLast
Results 41 to 80 of 143
Like Tree8Likes
Thread: RobMorris Audi A4 2.5 V6 tdi avant
  1. #41
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    538
    nice - ive grabbed one but paid just over £30.. let us know how you get on - i shall tackle mine next weekend i hope!
  3. #42
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    538
    As im waiting for parts - i grabbed a few hours to start the deep clean!
    Removed the rear bench/front seats/and some panels from the boot..
    Have a before and after pic after I cleaned the drivers seat.. Its still damp but considering the brown water I poured away its now a lot cleaner! Fingers crossed it will dry nice?
    And I had a go at the carpets also..
    I found nearly £4 in change, a winch handle, various child related toys/pens/diary and a gold ring! (well.. gold plated costume jewellery..)
    Before and after
    Carpet
    and the beast i bought from argos this morning (i wanted one for the house anyway.)
    Its coming along..
    peposhi likes this.
  4. #43
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    538
    Fitted the interior back in today which was easy enough but
    Q****Now thw airbag light s on? Assume its where I took the seats out - what do I need to do to rest it?
    Then I done a service..
    First up I changed the air filter
    Old vs new
    And then the cabin filter
    The oil was blacker than black! It was also so thick..
    I got told off by the missus for using up the kitch roll trying to absorb the dirty oil out of the oil filter housing.
    I was supplied a rubber ring gasket for the lid but oil peshed down the side of the housing when the engine was running so took it off.
    At this point I though about changing out the glow plugs but couldnt see where they were for grud!
    I went to the local parts shop and bought 2 cans off GUNK. Drove down to morrisons and bought 2 x 2.5 mins jet wash time..
    Used up 1 tin on the dry engine, waited 5 mins and sprayed it off.. then on with the 2nd can, 5 mins and spray again..
    I was really happy with the result, unfortunately didnt take a before pic.
    After this I continued to do bits. I sprayed up the door hinges etc. Fixed the rear ash tray..
    Then I thought id check the spare.. Here it is.. or was? Ive had the tyre replaced today but i am missing the jack and wheel brace?
    Can you spot my first mod? EGR stop..
    In this pic also can you see the bottom metal block with yellow paint? What is this? It make a lot of noise!!
    Does anyone know wht this is? it looks like it should have a belt fitted?
    From up top
    and from underneath
    Cheers!
  5. #44
    scottshere's Avatar
    Dec 2010
    South Yorkshire
    337
    This is my favourite build
    A4 1.9TDI Sport - 130 (B6) / Mods: None yet, just getting the basic right first
  6. #45
    Apr 2012
    lincs
    210
    ^ is the air con compressor - if clutch / pulley siezed then it's either new pulley c.£150 + labour + regas (if you have to take it out to unsieze) or new compressor £250+ or 2nd hand one - there's some on 'bay for about £50 but make sure you get the rightone - the 2.5 is a specific one. - part number 8E0260805C or R or AK (depends on engine type AKE,etc)
    can be done with front end in place (not in service pos) with difficulty.
    keep up the good work!
    And
    A4 2.5 tdi Q sport '02 AKE, "minor modder", 18x8's S4 Avus , Zender Monza's 18x8.5's, aero wipes, interior trim, dis and cruise, real s4 mirror caps, rns-e led, dble din, VCDS owner-learner - GMBH next
  7. #46
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    538
    cheers mate - it gets cold enough on low so il guess il leave it be.. (might change my mind in the summer!)
  8. #47
    crazy88's Avatar
    Loving the anonymity
    West Yorkshire
    4,806
    Re: RobMorris Audi A4 2.5 V6 tdi avant
    I love this thread! Loving the updates too. I might take my seats out this summer for the carpets to be cleaned, looks like you can get a much better job done.
  9. #48
    Aug 2011
    198
    Yes. It's certainly a fascinating thread.
  10. #49
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    538
    if you want to clean the carpets then you must take the seats out! Its really not a difficult job and very straight forward to do with needing any instruction. My only tip would be to pump the seat up to full height to gain easier access to the spline and torx screws + the seat belt removal from the seats..
    First though seek out what is needed to reset the airbag light as mine is on now..
  11. #50
    crazy88's Avatar
    West Yorkshire
    4,806
    You can reset airbag lights with vcds. Did you turn the ignition/ car on with some airbag connectors not reconnected? I know that can cause a problem with the steering wheel.
    I have vcds though, so that won't be a problem. Thanks for the tip regarding the seat height though.
  12. #51
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    538
    Yeah I drove to to the shops with the passenger seat still in the garage drying!
    might have to invest in the vcds?
  13. #52
    crazy88's Avatar
    West Yorkshire
    4,806
    That'll probably be it then See if there's anyone local with vcds? The genuine lead is around £250, so not cheap.
  14. #53
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    538
    do i need genuine?
    ebay for about £15?
  15. #54
    crazy88's Avatar
    West Yorkshire
    4,806
    Not sure, i've only ever used the genuine one. People have reported success with a non-geniune lead, but best to wait until someone who has actually used one can confirm for you.
  16. #55
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    538
    For the sake of £15 ive grabbed one myself. Fingers crossed it will be ok..?
  17. #56
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    538
    Does anyone know how to change the display? IE what MPG im getting etc, it currently reads how many miles left to empty..
    I did a search and there should be a button on my window wiper stalk to switch through the displays but mine doesnt have a button?
  18. #57
    kite's Avatar
    Oct 2007
    East Berks
    675
    If you don't have the button then you don't have full DIS.
    You can retrofit it though.
    I think theres a "how to" on here. Have a search.
    Most people retofit cruise control at the same time.
    A4 (b6) 2.5 TDi QS Saloon.
  19. #58
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    538
    Thanks mate - il have a read up
  20. #59
    crazy88's Avatar
    West Yorkshire
    4,806
    You'll also need vcds to code the car for DIS and cruise. (not sure the ebay cable would be up to that, but give it a try when it arrives)
  21. #60
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    538
    Ive had my delivery of 4d carbon fibre look vinyl! I paid £9.99 from ebay for 50x150cm..
    It looks great and is really tough and durable.
    As I had one door trim off anyway I went about getting it wrapped!
    I took my time and from start to finish it took about half hour to complete this trim piece.
    First I washed it down with soapy water then rinsed it off with clean water.
    Dryed it with a towel and then really dried it off and warmed the piece up with the hair dryer for good adhesion..
    Laid it on the vinyl and cut a piece with about an inch excess all around.
    Starting from the thin end on the flat surface I went along the piece making sure there were no bubbles/creases etc, then cut little nooks along the trim and reheated as I went along and stuck the pieces down firm.
    The ends were a little tricky but I just warmed up the material and took my time and stretched it round the corners so that there were no folds/overlaps etc.
    I can only do 1 at a time as my finger tips are so sore from pulling the material hard around the corners whilst the heat from blow dryer was burning them at the same time!
    Anyway have some pics
    My trim next to the roll of material - I went for dark grey colour.
    And just a couple of pics of the ends. The straight is just straight..
    Cheers Rob
  22. #61
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    538
    Postman brought me a couple of prezzies today..
    Some Infinity Coaxials to replace the stocks.. Ive not started the install as yet.
    And had my one of these delivered today
    VCDS lite VAG AUDI VW SEAT SKODA Diagnostics Interface | eBay
    ..VCDS Lite. Was a bit of a hoe bag to install on my lap top - but done it eventually..
    Cleared the airbag light and a few other codes that come up.
    2 problems it did find was my brakes and my drivers side electric mirror?
    I then seeked out how to reset the service warning which i used this vid for guidance
    https://www.youtube.com/watch?v=PvOVympP4HY
    I called various breakers for replacement bumpers and switches. no luck with the bumpers but picked up some nearky new window switches..
    I then went about de-badging the rear. Didnt grab a before pic but here is a pic after I used floss to safely cut the letters/number off. I then used tar remover to soften the foam/glue and just scraped off this with my finger nail.
    Then I got out some T-Cut and buffed the remaining muck off.. Well happy with the result and with absolutely no hint of paint fade etc..
    I was getting cold so had a play indoors.. Took my door handle off and apart and wrapped it..
    before
    after
    then whilst I was on form
    Cheers!
    steamship likes this.
  23. #62
    Jan 2013
    Ardmore, Co.Londonderry
    160
    Good job Rob. That's what I'm hoping to wrap once I get the car cleaned and then decide and what sort of wrap.
  24. #63
    Mr-C's Avatar
    Feb 2013
    Chorley
    199
    Looks like the 4D carbon wrap
  25. #64
    Mar 2012
    188
    Do the infinitys drop into the stock mounts on the doors?
  26. #65
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    538
    Yeah its 4D carbon wrap.
    Il be making my own MDF rings mate.
  27. #66
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    538
    grabbed a few hours today
    will let the pics do the talking (The eagle eyed will notice I had to redo a couple of pieces)
    Cheers!
    ruffrida and peposhi like this.
  28. #67
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    538
    Does anyone know how to remove both the cup holder and coin tray?
  29. #68
    crazypainter's Avatar
    Jun 2010
    Surrey
    587
    I reckon this is the birth of what will be an epic thread! How did you dress up the worn out buttons?
    Need pinstriping? : www.crazypainter.com
    A4.. 1.8T.. Remapped .. Saloon.. Atlas Grey.. Votex Kit..
  30. #69
    Jan 2013
    160
    Really like what you did with the climate control unit. Any chance of a pic with it lit up at night. I don't think I have the patience to do that but would like to redo my buttons, and having the red and blue around the edge looks nice.
  31. #70
    VagCabby's Avatar
    Apr 2012
    Crawley, West Sussex
    224
    I think I said it to someone before who did the sticker mod on the buttons. Surely it would have made sense to paint the buttons matt black with a small sticker over the momiddle then when dry remove the sticker and apply the new button graphic? Would give it the OEM look.
    Audi A4 Cabriolet 2.5TDI 163 Sport
    Full Interior Lighting Pack - Puddle Lights, Footwell Lights, Door Markers, Handle Ambient Lights, Air Vent Illumination, Armrest Illumination, Roof Ambient Lights. Auto Dim Rear View Mirror, Cruise Control, Full DIS, Genuine 6 Disc CD Changer in Glovebox, RNSE, Remote Windows, Parrot Bluetooth, Storage Pack, Full Leather, Heated Mirrors.
  32. #71
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    538
    Considering ive covered it in carbon its not exactly the OEM look I was after.. I really like the colour coming through around the edges..
    The buttons were fully cleaned/scraped off then I used these over the top
    Audi A4 S4 B6 8E climate control button buttons repair kit plus + minus - white | eBay
  33. #72
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    538
    FINALLY! After hours of web searching, 20ish emails sent, 7 breakers called, I have myself a lower front bumper..
    And its an S-Line/GMBH one! (Without grills) Il be following this thread.. (Including the ghetto grills)
    B6 A4: Ultrasport Lower Front Bumper with Stock Upper
  34. #73
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    538
    Went out for a good drive today but noticed my revs never dropped after warming, as if the electric choke never see that the engine had warmed?
    Whats wrong?
  35. #74
    Feb 2013
    13
    Thermostat?
  36. #75
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    538
    Quote Originally Posted by RobMorris View Post
    Hmm what to do with this screw?
    It 'was' a star screw that ive managed to round off..
    I first tried drilling but after 15 mins i managed about 3mm
    then i cut a slit to try screwdriver out but im still not having any luck trying to get out
    any advice?
    Got this sucker out yesterday. I hammered in a T30 bit I think it was and got it out!
    Have replaced the spline bolts with ordinary bolts to stop this from happening again..
  37. #76
    JimLoskot's Avatar
    Aug 2009
    Manchester
    155
    Prize the top cover off from the top and back and then it obvious
    2.5 tdi Quattro sport - PhatBox - DIS - Cruise - RS4 ARB - Remap - and a few other minor mods/retrofits
    2.0 TFSI A4 b7 cab - completely std for now... (the wife's car)
  38. #77
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    538
    Thanks Jim - I have removed the top panel and also the stereo. Im told there tabs in the top corners and to put a screw driver in to press them down? I cant get a screwdriver in on mine?
    Im wondering in the top trim removal ive left half of it behind?
    Il have to take a pic for someone to confirm..
  39. #78
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    538
    Quote Originally Posted by kite View Post
    OK. same sticker is in the boot. Normally the spare wheel well.
    Ive looked and cannot find the sticker in the boot/spare wheel well.
    Anywhere else I should be looking?
  40. #79
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    538
    This is for my PR codes..
  41. #80
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    538
    Oooh whats this the postie just dropped off?
  1. Audi A4 B6 1.9 TDI Sport (130) Avant
    By Mr Singh in forum For Sale/Wanted - Audi Cars
    Last Post: 15th October 2011, 23:56
  2. audi a4 2.5 tdi avant sline b6 b7 facelift
    By the jammy one in forum For Sale/Wanted - Audi Cars
    Last Post: 14th May 2011, 23:33
  3. Buying a 2003/2004 Audi A4 TDI Avant
    By Funkyfin2000 in forum A4/S4 forum(B5 Chassis)
    Last Post: 31st October 2010, 09:09
  4. DPF removal on Audi A4 (B7) 2.0 Tdi 170 Quattro Avant
    By Holywood in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 3rd July 2010, 19:14
  5. audi a4 tdi avant
    By stonecold1163 in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th January 2006, 19:15
