Sky InsuranceAH Fabrications
    Jan 2013
    Northern Ireland
    71
    Engine mount help!!!
    Hey all, I require a passenger side engine mount for my 1.9 tdi 130bhp a4 saloon, does anyone know the part number? Also I have been quoted (from the stealer's) £114 for it which I'm reluctant to pay. I'm wondering if there is a solid replacement for it? hopefully a bit cheaper? Thanks.
    Feb 2013
    Newcastle
    43
    I think i may have one, al check mate
    Feb 2013
    On most B6 the passenger side is normally the electric one, which gets harder when power is applied, which is why they are so pricey and no one does them apart from Genuine.
    They only way of being able to fit something cheaper is if you can trick the ECU into thinking the electric one is still fitted, with a suitably sized resistor or something like that, otherwise it will keep throwing up a fault code.
    How do you know its dead? Is it throwing a fault code saying 'short to ground', or is it just that its leaking purple fluid?
    Jan 2013
    Northern Ireland
    71
    a solid replacement? the car is the 2001-2005 model if that makes any difference mate.
    Jan 2013
    Northern Ireland
    71
    Quote Originally Posted by Enzo_UK View Post
    There is a fault code on VCDS and the fact is all bulges and bursted. Guess im going to have to go genuine then
    Jan 2013
    Northern Ireland
    71
    Quote Originally Posted by jayc94 View Post
    anyone got he part number?
  1. help lower engine mount bushes
    By mozza1202 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th September 2012, 20:43
  2. Engine Vibration - Would a new snub mount help?
    By jdp1962 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd August 2010, 17:15
  3. Help locating / replacing engine mounts - pics please!!!
    By technics100 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th July 2010, 20:14
  4. Possible engine mount problem? Help please
    By moorheadbrian in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th June 2010, 17:27
  5. help buying new engine mounts.
    By Jonesy in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th October 2006, 08:57
