JMB RetrofitsVolks Autos
Results 1 to 20 of 20
    Oct 2010
    62
    Do I need a stereo harness adapter
    Hi all, I have a 1.9 TDi sport avant, I have just brought a second hand Sony headset http://reviews.halfords.com/4028/151525/reviews.htm from a lad at work, the question is will this fit straight in or will I need to buy the wiring adapters because I've got to go to Halford anyway to get the stereo removal keys
    Oct 2010
    62
    Re: Do I need a stereo harness adapter
    Ok so I fitted it but the original wiring as three plugs one for live, earth etc, one for front speakers and another for the rear but the new stereo only has two plugs so do I need some kind of adapter?
    Feb 2013
    You should have two 8-Pin ISO plugs, one for power and the other for speaker, and these should plug straight into an aftermarket stereo.
    If there is a third plug that is different, I would guess its for a changer, or something like that.
    Oct 2010
    62
    I think the third plug is for the rear speakers because at the moment I don't have any audio coming from the rear when I set the fade to the rear
    Oct 2010
    62
    I also have this mystery plug in removed from the stock radio
    Feb 2013
    The first pic apears to be a 'Mini ISO' used as a line out for feeding an amp, like on cars with Bose.
    They are normally in three bits that pull apart, yellow, green and blue... one bit for changer, one for phone, and one for line out, but looks like its all in one, but only one end is used.
    Second pic shows the two 'ISO' plugs, the black one is the power, and the brown one is for the speakers... but on the speaker one only 4 of the 8 pins are used, so you are correct only the fronts are fed direct from the stereo.
    I would guess there is a factory fitted amp in the back of the car, in my Saloon with Bose it is on top of the drivers side rear wheel arch.
    Third pic looks like a 'Fakra' which is normally used for aerials, or GPS, etc... is there a more normal aerial type plug there aswell? If so it could just be left from some phone prep kit that has been in there in the past.
    I dont really know what your options are, such as if you can feed the amp using the line out on the back of a normal radio, never tried to do it, but someone must know.
    dale86's Avatar
    Oct 2012
    354
    Yeah you need a harness mate for rear amped speakers can be bought from Halfords it clips into your remaining plug
    Also if you like send me your num and ill send a pic and you can post it up if you like as it may also help others. I dont know how to post pics lol.
    Oct 2010
    62
    Quote Originally Posted by dale86 View Post
    Sent you a PM with my email if you want to email that picture over.
    There is a standard aerial plug but I need an adapter to make it fit the stereo.
    Also I do have a parrot hands free fitted which was plugged into the standard stereo, can this be wired to the new stereo?
    dale86's Avatar
    Oct 2012
    354
    Im not sure on the parrot as ive never fitted one but im more tjan certain it can be done and you will need an aerial adaptor female to male can be purchased also from halfords and email is on the way hope it helps.
    Oct 2010
    62
    dale86's Avatar
    Oct 2012
    354
    I cnt tell from that pic mate all i can tell you is it about the same price as the one I purchased lol best to go in store an compare to the pic i sent you shud be right as long as has the sepperate plug for you rear amped speakers
    Feb 2013
    The Parrot should just plug in between those two 8-Pin ISO plugs and the new stereo.
    Oct 2010
    62
    Quote Originally Posted by Enzo_UK View Post
    Sorry mate, can you be more specific
    Oct 2010
    62
    Have u sent the pic, I haven't received it yet
    Rudedaubin's Avatar
    Oct 2011
    South Yorkshire
    70
    The mystery plug you have shown is a seperate Fakra aerial feed which you wont be using with the new radio. You can just leave it tucked out of the way. Your new radio will only need the standard aerial wire fitting ,although you will need an aerial adapter to power the booster or you'll get no reception.
    With regards to the other connections, the power and the front speakers will go directly into the back of your new radio.The rear speakers will probably need an adapter to connect either to the rear rca output on the radio or to the speaker output through a line converter. Finally there's no accessory wire on the existing car wiring so you'll need to either link the permenant live to the accessory live on the radio , or wire in a relay using a switched 12v feed from the igniton key .
    Did mine a couple of months ago , although mine was Bose so I didn't have the iso plug for the front speakers. Also not sure on wiring the Parrot but it sounds like it should just work through the front speakers anyway.
    2004 A4 Sport Cabriolet 3.0
    Oct 2010
    62
    Or is this the lead in need
    http://www.halfords.com/webapp/wcs/s...5876&langId=-1
    Does anyone have a pic of the lead in need as I don't want to pick the wrong one up
    dale86's Avatar
    Oct 2012
    354
    Yeah ive emailed you 2 pics mate ill try again now and check sent to roght address
    That isnt the lead i have i think thats for newer a4.
    Oct 2010
    62
    Still not received mate, have a check
    Oct 2010
    62
    Just found this Autoleads : Aerial Adaptor for AUDI A4 (2004-2008) Quadlock System-Half Amp - would it be best to conect using the faktra or just buy a adapter for the other Ariel lead
    Ok im looking on Car Audio Systems, Car Stereo, Car Radio DAB Stereos, Car Speakers Amplifiers Head Unit for a wiring harness, is my car half amplified ?
    Rudedaubin's Avatar
    Oct 2011
    South Yorkshire
    70
    No thats the lead for a B7, you will not need to connect anything to the Fakra plug. Your car will have 2 aerials , 1 is a standard co axial type and the other is a Fakra type. Aftermarket radios can't use both so you only need an adapter for the co-ax plug. Here's a link to what I think you will need.
    In Car Entertainment, Bluetooth & Multimedia fitting solutions and interfaces
  1. Aftermarket stereo/iso adapter help needed!!
    By nixy in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd September 2011, 13:11
  2. Help needed with stereo system
    By Cookie0125 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th June 2010, 22:36
  3. Which Stereo Harness
    By Ryanmt in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th June 2010, 09:33
  4. got an audi A3 1.6, what harness adapter? theres loads!
    By Zenin in forum In-Car Entertainment
    Last Post: 22nd May 2009, 18:26
  5. Stereo harness question
    By CurioCT in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th April 2007, 20:19
