Badger5Sky Insurance
Results 1 to 11 of 11
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    538
    Wheel bearing replacement
    Chaps
    I need to replace a wheel bearing on the front.
    Is it easy enough for me to replace myself I do I need to take to a specialist mechanic with specialist tools?
    Ive seen on eBay a bearing for £10 or a kit for £30 which looks like a simple bolt on?
    Aug 2011
    195
    I could stand to be corrected on this, but when I looked at doing the same job the words "hydraulic press" in the context of getting the thing on, kinda pointed me to my local friendly garage.
    Oct 2009
    Hull
    1,440
    Re: Wheel bearing replacement
    I did mine without a press
    Although the bearing can be tight in the strut as I found out!
    Aug 2011
    195
    DIY: Front wheel bearing replacement
    Just stumbled upon this - might be helpful?
    2,158
    on the B6 it's a bolt on bearing, but is till a bugger to get the thing out. The £10 bearing are for the B5 model. Also I would be looking to pay more than £25 for a bearing unless you want to replace them every 6 months. Make sure you get new bolts, and your going to need a torque wrench & big ass breaker bar!
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    538
    Cheers Mike - ive printed that 'how to' out and im 50/50 whether to tackleit myself or use a mechanic.
    it looks simple enough..?
    Cheers B5NUT - ive bought a bearing kit for £35 that comes with fresh bolts..
    I do have a torque wrench but need to get a couple of tools as per the above 'how to'
    Oct 2009
    Hull
    1,440
    When I did mine it took some welly to get the bearing out but it came out
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    538
    DIY is there a way around using a bearing press with this?
    Alan H's Avatar
    Need a V8 or Bi-Turbo.......
    Aug 2010
    Dudley, West Midlands
    453
    When I did mine I just undid the bolts then drifted the bearing out with a copper mallet. It was a bit tight, but not seized in or anything.
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    538
    cheers mate then you banged the new one back in?
    Alan H's Avatar
    Aug 2010
    453
    Quote Originally Posted by RobMorris View Post
    Basically yes. Just make sure it's square before you start tapping it in, then you can use the bolts to pull it flush. Tighten the bolts as though you were tightening a roadwheel.
  1. HELP .. Wheel Bearing Replacement - Audi Main Dealer!!!!
    By c15luf in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 28th May 2012, 14:57
  2. A3 rear wheel bearing replacement queries...
    By richrich14 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th October 2011, 21:40
  3. Rear Wheel Bearing replacement.
    By P Crr in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 19th February 2010, 18:22
  4. ABS light on after wheel bearing replaced?
    By dgo1212 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 30th August 2009, 21:14
  5. Front Passeneger wheel bearing replacement - Any tips or guides
    By technics100 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 29th September 2005, 18:48
