Badger5Chris Nott
    scottshere's Avatar
    Dec 2010
    South Yorkshire
    337
    Best place for a dirve shaft?
    Been told i need to replace my NS driveshaft
    Well told it would be better and easier to change it rather than the inner joint and not 100% confident the outer CV joint is in good condition
    Struggling to find a replacement, looking at recon ones and the only place i have found so far is
    Drive Shafts - Car Parts Direct
    £280 delivered - Ouch
    Or do i just buy the inner and outer joints and have them fitted?
    A4 1.9TDI Sport - 130 (B6) / Mods: None yet, just getting the basic right first
    Feb 2013
    Is it definately a inner CV that is knackered, as they dont tend to go that often, unless you have been driving with a split boot for a while.
    If it has the newer tripodic type inner joint you cant usually take them of the shaft, so a whole shaft is the only way to go on these.
    If its an older ball and cage one, then just get an inner CV, as is not much that can go wrong with the shaft itself.
    scottshere's Avatar
    Dec 2010
    South Yorkshire
    337
    Quote Originally Posted by Enzo_UK View Post
    I believe the inner one has some wear and is moving (so we think)
    Have a strange click/metalic knock when i stop and start on both sides. The drivers side we believe is the CV joint (or should i say hope) as it is def worn and has now started to click. There is also some vibration/wobble at 80 which does not happen all the time and again feels like it is from the nearside. Had all the front arms/droplinks/tie rod ends replaced as a kit and this did not cure it.
    We are hoping the a CV joint on the offside and a shaft on the nearside fixes things
    As i said, it does feel as if it is the inner one that has some movement and is intermitent with both the wobble and the click/knock
    But as usual, any ideas/advise is more than welcome as who knows if we are right :-)
    (just hope to stop spending money on this issue so i can start a few mods)
    scottshere's Avatar
    Dec 2010
    South Yorkshire
    337
    CV joints replaced and still getting a wobbling feeling, Thinking it maybe the inner joint now.
    I thought it may be the dual mass, but even if i take the car out of gear it still wobble the same whilst free wheeling
  1. Best place for mirror caps?
    By gurds_1 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th May 2006, 02:22
  2. Where is best place for an RS4 Bumper + M3 Style Back Fin?
    By imported_ZeroK66 in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd August 2005, 16:51
  3. Best place for Ringtones?
    By dickys3 in forum General Chat
    Last Post: 20th November 2004, 18:26
  4. best place for an audi?
    By viper in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th October 2003, 11:12
  5. Best Place for a deal on Tyres
    By fraz in forum General Chat
    Last Post: 16th April 2003, 14:06
