Badger5AH Fabrications
    Dec 2012
    Northants
    217
    Little mayo on dipstick, normal for this time of year??
    Noticed a small amount of mayo on my dipstick a couple of times now, absolutely no signs of it under filler cap. Everything else is as it should be. I've recently had the thermostat changed as it stopped working. My commute to work is 10 miles which takes around 15 mins. Just wondering if its normal at this time of year. Should I change the oil???
    If it's got tits or gears it's gonna be expensive.
    dpbayly's Avatar
    Oct 2012
    Royston, Herts
    368
    I've seen this a few times mayo on the dipstick on cars in at our garage and it was there due to emulsified oil sitting in the dipstick tube and not the oil its self it can collect in there much like it does when it collects in the top of the engine condensation mixes with the oil and makes the mayo type substance so the as long as the oil on the end of the dipstick is normal then you have nothing to worry about
    Dec 2012
    Northants
    217
    Cheers bud, it is near the bottom of the dip, it I pull it out and wipe it x2 then there is no trace of it.
    There is also traces of it half way up/down the stick
    dpbayly's Avatar
    Oct 2012
    Royston, Herts
    368
    Thats fine, no issues there
    Dec 2012
    Northants
    217
  1. Thanks to t8ups this time for the sidelight LED's
    By cjsuk in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th July 2012, 17:34
  2. Yet another daft question time! - This time, silicone hoses for S3!
    By Nogmeister in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st July 2012, 21:58
  3. Replies: 3
    Last Post: 30th December 2010, 20:21
  4. Is it normal for a VCDS scan to take this long?
    By AndyMac in forum VCDS (formerly VAG-COM) forum
    Last Post: 14th July 2010, 14:27
  5. Is this normal for a 2005 A3 DSG!?!
    By AJ-S3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th September 2009, 17:11
