EM TuningBadger5
Results 1 to 14 of 14
Like Tree1Likes
  • 1 Post By Steffgj
Thread: EGR Gasket ?
    scottshere's Avatar
    Dec 2010
    South Yorkshire
    337
    EGR Gasket ?
    I'm looking at removing and cleaning the EGR this week (dirty task i know)
    Do i need and gaskets replaced or is it just a bolt off and back on?
    A4 1.9TDI Sport - 130 (B6) / Mods: None yet, just getting the basic right first
    S3 GAZ's Avatar
    Dec 2006
    East Ayrshire Scotland
    343
    Re: EGR Gasket ?
    Planning on doing this aswell can anyone tell me if we need to replace a gasket?
    Jan 2013
    Bath
    69
    Not done this yet but I'd think that replacing a gasket is always better than using the old one. Might as well if it's already off and they're only about £6!
    S3 GAZ's Avatar
    Dec 2006
    343
    Re: EGR Gasket ?
    More I wasnt sure if there was a gasket in there. I have a leak in mine somwhere
    Jan 2013
    Bath
    69
    Yep pretty sure there is. Same here, quite clearly oil coming from between the EGR and the intake manifold in mine so it's coming off next week!
    S3 GAZ likes this.
    S3 GAZ's Avatar
    Dec 2006
    343
    Re: EGR Gasket ?
    Il have a kook now and ket you know how I fair
    benjie's Avatar
    Oct 2009
    Swindon - home of the 'Magic' Roundabout.
    645
    I have done this and yes there is a gasket and YES change it otherwise you'll get an awful leak. Seen it recently on my friend's 130pd Passat B5.5.
    It's costs like £5-6 from Audi (bit steep for a bit of rubber, but heigh ho). Totally worth it and a relatively easy job if you have fingers that bend the wrong way to loosen the allen key bolts from the car! I think they're allen key ones anyway. Been a few years since I did it!
    B8 S4 Avant in Misano Red with some lovely toys!
    Prev: B6 A4 Saloon 1.9 TDI quattro Sport - great car.
    S3 GAZ's Avatar
    Dec 2006
    343
    Re: EGR Gasket ?
    Great stuff. Il get on from audi before tackling it. Replaced all the vacuum pipes today. So just egr and mr muscle to do
    Jan 2013
    Bath
    69
    How long did it take you to do the pipes and where did you get the new ones from? Just standard vacuum tube?
    S3 GAZ's Avatar
    Dec 2006
    343
    Re: EGR Gasket ?
    About an hour to change all hoses. Bought 5m 3mm of silicone hose from ramair on ebay. £10
    Its a nice fit on the smaller hoses and stretches to fit the bigger ones
    scottshere's Avatar
    Dec 2010
    South Yorkshire
    337
    does the silicone hose not melt?
    i thought the original hose is threaded to help protect from heat?
    S3 GAZ's Avatar
    Dec 2006
    343
    Re: EGR Gasket ?
    Its the same silicone they make boist pipes and TIP and used in race engines. Treated and designed to withstand heat.
    So no I dont think it does
    scottshere's Avatar
    Dec 2010
    South Yorkshire
    337
    Got a link to the actual stuff you used?
    Im guessing any old tubing from ebay wont be the same
    S3 GAZ's Avatar
    Dec 2006
    343
    Re: EGR Gasket ?
  1. Blanking plate for EGR valve. Does it work wonders
    By Holywood in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th May 2004, 15:12
  2. EGR Cleaning
    By MartinReid in forum Diesel forum
    Last Post: 7th May 2004, 10:06
  3. Star Performance Testing Day Pt3 Power Gasket
    By Ess_Three in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th February 2004, 18:36
  4. POWER GASKET... ANYONE
    By ooooaudi in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th December 2003, 15:34
  5. EGR valve
    By Pookie in forum Diesel forum
    Last Post: 29th July 2003, 16:11
