AH FabricationsVolks Autos
    Nov 2012
    Renfrew
    23
    Oil Level Sensor (Yellow Oil Can on dash)
    Hi Guys, i am having problems with my 2003 audi A4 2.4 v6 Cabriolet. The yellow oil can Sensor recently flashed up so i checked the oil which was ok. Reading a few posts on line assured me that it is the level sensor so most probably a dodgy sensor. As changing the sensor would involve dropping the oil, i waited a couple of weeks and did a full oil change.
    I purchased a sensor from GSF and fitted the new one. Problem is still there !!!!! I reset all the codes with VCDS but the light is coning back on. The annoying thing is that it seems to come on after about 5 mins of driving and one day it never came on at all (this was a good day).The wires and the connector all looked ok so no reason for me to think this was the problem.
    Someone suggested the fuse but a checked all the ones in the side of the dashboard, is there another fuse box?
    Ill check the wiring to see if its worn anywhere.
    This is the codes im getting on VCDS
    Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
    Part No: 8H0 920 950 A
    Component: KOMBI+WEGFAHRS. RB4 D02
    Coding: 00401
    Shop #: WSC 25042
    VCID: 2A5F5DE9D6D9E3485F8
    WAUZZZ8H63K004328 AUZ6Z0B0130901
    2 Faults Found:
    00562 - Sensor for Oil Level/Temperature (G266)
    29-00 - Short to Ground
    27-00 - Implausible Signal
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,947
    could it be at the bonnet catch
    i know they work from there aswell
    Az
    Az's Avatar
    Hard slammed!
    Jun 2008
    Hertfordshire
    1,023
    Did you check the wiring leading to the sensor? I had an intermittent dash light on mine a couple of years ago for oil level and it turned out to be damaged wiring and slight corrosion on connectors, never replaced the sensor itself but had the wiring replaced and it's has never shown its face since.
    B6 A4 2.5 V6 TDi Quattro Sport
    Dolphin Grey I 210 BHP Remap I KW V1 Coilovers I 19"x9.5" all round BBS LM reps I RS4 Anti Roll Bar Kit I S4 Front and Rear Bumpers I Votex side skirts I S4 Aluminium Mirrors I S4 Rear Spoiler I S4 Style Tailpipes I USDM S4 licence plate blank I 6000k HID's I 18 SMD DRL's I Cupra R Splitter I Full RS4 black leather with white stitch optional bucket seat interior I RS4 black headlining I TT S Line FBMFSW I Aluminium Trim I Reverse camera I Full DIS I Cruise Control
    Nov 2012
    Renfrew
    23
    Ill have a look again but all seemed ok at the time!
    cheers
    Nov 2012
    Renfrew
    23
    Ill have a look at the bonnet catch as it was throwing a fault code aswell.
    cheers
    Feb 2013
    Hi i had same issue on my 2007 a4 2.0 170 bhp low oil light on (orange) oil was new and full ( MAKE SURE IT IS FULL) !!! easy order to fix
    1: look at fuse 5 10amp make sure not blown( or goin bad / brown inside replace with good one)
    2pen bonnet sray degreaser all around bonnet lach and use small swrewdriver and paper cloth clean ALL dirt an muck off even push lach into closed possion to get to other areas when fully cleaned spray with some sillicon lube or penatrating spray wd40 all latch( i came to the thought that maybe the latch contact links in with the sensors earth circuit ) there for dirt wont let it contact breakin the loop.
    If not cured it
    3: dissconect batt poss and neg for 20 mins to force computer into reboot
    4: take out oil level sensor clean with elec contact spray replace and make sure plug wire is free from dirt.
    5: STILL ON new sensor
    6: make sure no fault codes on VAG-COM or AUDI £££$$$
  1. Oil level sensor problem ?
    By luis.filipe in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 22nd April 2011, 22:32
  2. Oil level sensor
    By ianysm in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st January 2010, 22:14
  3. Sump oil level sensor conversion
    By lucksta in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th April 2009, 20:46
  4. Oil Level Sensor on Early S3's?
    By metricspaces in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th February 2009, 16:08
  5. Replies: 1
    Last Post: 17th August 2007, 23:10
