Hi Guys, i am having problems with my 2003 audi A4 2.4 v6 Cabriolet. The yellow oil can Sensor recently flashed up so i checked the oil which was ok. Reading a few posts on line assured me that it is the level sensor so most probably a dodgy sensor. As changing the sensor would involve dropping the oil, i waited a couple of weeks and did a full oil change.
I purchased a sensor from GSF and fitted the new one. Problem is still there !!!!! I reset all the codes with VCDS but the light is coning back on. The annoying thing is that it seems to come on after about 5 mins of driving and one day it never came on at all (this was a good day).The wires and the connector all looked ok so no reason for me to think this was the problem.
Someone suggested the fuse but a checked all the ones in the side of the dashboard, is there another fuse box?
Ill check the wiring to see if its worn anywhere.
This is the codes im getting on VCDS
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8H0 920 950 A
Component: KOMBI+WEGFAHRS. RB4 D02
Coding: 00401
Shop #: WSC 25042
VCID: 2A5F5DE9D6D9E3485F8
WAUZZZ8H63K004328 AUZ6Z0B0130901
2 Faults Found:
00562 - Sensor for Oil Level/Temperature (G266)
29-00 - Short to Ground
27-00 - Implausible Signal
Coding: 00401
Shop #: WSC 25042
2 Faults Found:
