Results 1 to 8 of 8
    JimLoskot's Avatar
    Aug 2009
    Manchester
    155
    drivers door lock mechanism
    Have had the fairly common drivers door bouncing back when you go to shut it.
    I have removed the door lock and given it a good soak in WD40 and cleaned it and greased it up but it still doesn't spring down to the fully open position.
    It appears that some of the rubber coating of the latch is damaged and may have come off or is catching on something internally.
    As a temp fix, I have lowered the stricker plate so that it forces the latch further down when being opened but is only a temp fix.
    A new lock is approx £140 from TPS.
    Has anyone taken the lock mechanism apart and sucsessfully cleaned and fixed this or similar issues?
    My worry is if I strip it down, the thing will explode with springs and pins flying everywhere
    2.5 tdi Quattro sport - PhatBox - DIS - Cruise - RS4 ARB - Remap - and a few other minor mods/retrofits
    2.0 TFSI A4 b7 cab - completely std for now... (the wife's car)
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    beverley,East yorkshire
    1,196
    has your door dropped slightly?, thats the cause of why my passenger door doesnt shut very well
    JimLoskot's Avatar
    Aug 2009
    Manchester
    155
    No, the doors are fine. Its the lock mechanism that doesn't spring down to fully open.
    Has anyone taken a lock mechanism apart with success?
    JimLoskot's Avatar
    Aug 2009
    Manchester
    155
    for future reference I bought a lock off ebay fairly cheap, when that is fitted and working I'm going to try and take apart my old lock and I'll post up the results
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    538
    Hi mate have you got a link to what you bought?
    RobMorris's Avatar
    Sep 2011
    Aveley, Essex
    538
    Hi Jim - did you fit the new door latch yet?
    sportquattro's Avatar
    Sep 2009
    Ivybridge, United Kingdom
    717
    Got the same problem here, is there a known problem? (have searched but cant find anything)
    1999 Audi S3 Superchips remap, Forge 007p, Phatnoise, Black Diamond Discs & DS2500 pads, N249 Deleted, Badger 5 TIP, Poly dogbone bush, Bilstein B8's and Eibach Springs.
    1986 Audi Coupe Quattro 2.2 restoration project
    glenandem's Avatar
    Sep 2012
    manchester
    448
    Hi pal, if your talking about the actual bit that hooks round the striker plate on the body, I had the same problem with mine not fully opening when you open the door then when you go to shut the door it smacks against the striker plate as its gone back to closed position!
    best thing I did without replacing it was just adjust the striker plate on the b pillar enough just to give it the momentum to open more and not go back on itself, took a few times trying to adjust it just enough but not too much but it's been fine since and I'll just keep it like that until it stops working again and I'll have to replace the mech but don't adjust it so doors out of line either!
  1. How to get to drivers door lock mechanism
    By just017 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st December 2011, 00:53
  2. Drivers door Lock - Central locking
    By andysAko4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th February 2009, 16:51
  3. Drivers door lock not registered as locked
    By WildBruce in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th December 2008, 11:21
  4. a4 drivers door lock
    By MIDCO in forum Diesel forum
    Last Post: 5th December 2006, 12:50
  5. Part Number for Door Lock Mechanism/Sensor
    By S3DBW in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st July 2006, 21:52
