Chris NottAH Fabrications
    Ollie-B's Avatar
    Rockin' Shnit
    Dec 2012
    Stanley, North East, UK
    292
    might be a silly question about back lights
    Can you get led rear clusters or is it just a bulb replacment for leds?. Same with rear no.plate lights? Thanks
    blacksmoke remap, 18" alloys, coilovers, heko wind deflectors, c/coded door blades, DIS, Cruise, votex front grille
    TO DO: fit my votex front valance (in the shed), c/code the rest of the lowers, sport interior
    Oct 2012
    487
    Led units mate about £160 to £250 i think depending which ones i think a couple of members on here do the conversions
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    534
    U can also get led bulb replacments for the back lights
    Watch out for bulb warning light,non canbus.
    1.9 avf 6 speed. Bv43 turbo. Swifttuning custom map. Powerflow straight through twin pipes. Allard delete kit. Boost,egt, + voltage gauges. Ball,spring boost controller. Fk silversport coilovers. 312mm brake upgrade. B7 multifunc steering wheel. Full dis. Cruise control. Auto locks. Rs4 rear bumper. Full rs4 grills. Drls + hids. 10inch custom sub + amp. Leds everywhere. Parrotkit full speaker streaming. silver 4d carbon interior.never ending...
    BahnStormer77's Avatar
    BahnStormer
    Feb 2009
    Surrey
    2,579
    two options on the number plate lights: about £6 each (ish) for replacement LED panels to go into the plastic unit.... OR about £15 each (I think!) and get the new Audi A3 ones which are full replacement of the plastic unit with built in LED's....
    LostBok/BahnStormer77
    Ollie-B's Avatar
    Rockin' Shnit
    Dec 2012
    292
    Ah that sounds good for the no plate lights 15quid for a full unit with built in leds where do i get one?
  1. A couple of questions about fitting lights!
    By S4P4UL in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 4th February 2013, 18:26
  2. question about interior lighting
    By patrick swayze in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th January 2008, 17:20
  3. Question about S3 lights.
    By Effect in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th June 2007, 17:32
  4. Might be a silly question
    By Biglee in forum Site Support & Announcements
    Last Post: 20th June 2005, 20:56
  5. questions about lights
    By Max_Arch in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th January 2005, 21:23
