Chris NottBadger5
Results 1 to 9 of 9
    Feb 2013
    North East
    22
    Question Central Locking Problems!
    Every couple of days the central locking just stops working, I have to re sync the key with the car (switching ignition on & pressing unlock) as the key fob buttons stop working, I've replaced the battery's on both of my keys so its not that, its starting to annoy me, is this a common thing? is there an easy fix?
    The second problem is that the button on the key fob (and the spare) does not unlock the boot at all so im having to put the key in & unlock it manually every time!
    Any help much appreciated
    A4 1.9 TDI Sport 130 GmbH Kit 6 SPEED
    Jun 2012
    Teesside
    448
    Your boot is probably down to the solenoid, common issue, unfortunately im not sure what could be causing your key issues, but im sure some other guys will be along soon
    Mods done: interior: Light to dark conversion, To Do: Carbon trim, carpet to be replaced, rear window retrofit. Exterior: Resprayed in Skoda's Rallye Green, 18" RS4 reps fitted, xenons, LED sidelights/NumberPlate lights, B Pillars wrapped in carbon. To Do: Lowering 35mm all round, tints, Tuning: Yet to do exhaust/remap/ egr delete etc..
    Oct 2009
    Hull
    1,440
    Re: Central Locking Problems!
    Boot could also be the wiring to it another common problem
    As for the key fob try bending the battery pins out this has worked for many including me the fob flexes and looses contact
    Feb 2013
    North East
    22
    Looks like im gunna have to get a boot solenoid then, does anyone know a rough price for one of these? where the best place to get it? main dealers?
    ill try bending the pins on the keyfob battery, hopfully that will work, thanks for the replies
    Oct 2009
    Hull
    1,440
    before you get a boot solenoid check your wiring its free and easy and just confirms that it is or is not the solenoid
    also when you open the boot does the display on the dash show that its open? if not this is one of the tell tale signs that its wiring as the boot lid probably wont have any power to it if the wiring is broke
    Feb 2013
    North East
    22
    Quote Originally Posted by stu_m View Post
    just checked and when I open the boot lid the display on the dash shows that the boot is open, so I guess it must be the solenoid? is there a 'how to' replace it on here? cheers
    Oct 2009
    Hull
    1,440
    It looks more like the solenoid then the wiring then
    not sure if there is a how to but it is easy to get everything out
    kite's Avatar
    Oct 2007
    East Berks
    675
    Is the key slot in the boot in the right position.
    Depending if the lock is vertical or horizontal it works with the central locking.
    A4 (b6) 2.5 TDi QS Saloon.
    Feb 2013
    North East
    22
    I think its horizontal, is that the right position?
  1. Central Locking Problem
    By chester2000 in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th November 2005, 15:17
  2. A4 Remote Central Locking Problem
    By inigoj in forum General Technical / How To
    Last Post: 1st May 2005, 22:39
  3. Central Locking Problem
    By Lowride in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th December 2004, 21:39
  4. Remote central locking problem!someone please help
    By Add7 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th July 2004, 13:43
  5. a4 central locking problem
    By imported_stunt_man_rob in forum General Technical / How To
    Last Post: 23rd June 2004, 22:10
