Badger5JMB Retrofits
View Poll Results: S4 4.2 V8 Oil Pan Removal - PLEASE HELP!
Voters
2. You may not vote on this poll
  • S4 4.2 V8 Oil Pan Removal
    0 0%
  • Oil Pan Removal
    0 0%
  • Oil Pan
    1 50.00%
  • S4 4.2 V8
    1 50.00%
    Feb 2013
    Chessington, Surrey
    Hi,
    Thanks for your time. Would anyone know how to remove the oil pan on a 2003 S4 4.2 V8? I have removed all the bolts with the exception of the bolts that are under a stainless steal pipe located at the very front of the engine - I think this is a coolant pipe.
    I am fairly handy around a car but I just cant find any instructions on how to remove the stainless steal pipe to gain working access to remove the oil pan. There are about 6 bolts that I are above the stainless steal pipe that are obscured.
    There is absolutely no room between the front of the engine to even see where the pipe goes! Rather than start pulling the entire front of the car apart could someone offer some advice on how to tackle the oil pan removal or provide some pictures please.
    Thank you. Neil
    Dec 2006
    barnsley
    1,017
    im sorry to say thats exactly what you need to do
    to remove that pipe you need to remove the front engine mount and ideally the only way to get at that is to put the front end of the car in to the "service" position
    2003 pearlescent black s4 avant tiptronic - milltek exhaust - pre cats removed - remapped ...
    koni adjustable suspension front and rear
    alpine f1 dvi9990 -pxah990 headunit and processor - alpine d511r
    4 x focal 5ws midbass drivers - focal audiom 6w midrange - focal tce tweeters - velodyne df 12 sc servo controlled subwoofer
    3 x phoenix gold zpa 0.5 amplifiers
    colinurquhart's Avatar
    Jun 2009
    200
    What's the reason for removing the oil pan?
  1. What is the recomended engine oil for S3 please
    By daztenerife in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th August 2013, 12:08
  2. Sump Removal ...please help!
    By lucksta in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd June 2009, 12:53
  3. A3 8L Quattro gearbox removal please HELP
    By A3Quattro1985 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th February 2009, 18:27
  4. Air Filter Element Removal - Please help
    By Platinum70 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th May 2006, 21:58
  5. A6 2002 - fitting parrott - help with trim removal please!!!
    By milo in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 15th August 2005, 15:00
Tags for this Thread
