EM TuningAH Fabrications
Results 1 to 9 of 9
    Dec 2011
    Wales
    106
    Correct gearbox oils Quattro manual
    Hi,
    Could do with checking the correct oil to change the diffs and gearbox on my manual B6 2.5tdi Quattro. Rang up my closet Audi stealer and they quoted me £30 for 5 litres of 75/90 semi synthetic oil. Not sure if they were just fobbing me off with any old oil.
    Is this the correct grade? Would appreciate members input into good suppliers and recommended oils for the Quattro service.
    Thanks.
    John
    Oct 2012
    388
    The grade is correct i would also use fully synthetic, i have used Millers oils in the past, but others have used redline,motul etc. The price is about right, box oil ain't cheap, you might wish to try euro car parts they also do semi and fully synth,
    Jul 2007
    London
    3,086
    Last time i bought gearbox oil in dealer it was about £16 for 1L ! I will be very cautious with oil from dealer that comes in 5L tins, unless it has the right markings ! Also gearbox oil from ECP is also a no, unless you're planning on a full rebuild in next 5-10k !
    FOR SALE:
    Dec 2011
    Wales
    106
    Thanks for the replies.
    Would it benefit to use a LSD 75/90 gear oil in the quattro?
    John
    Jul 2007
    London
    3,086
    Nope, only genuine oil for me in these gearboxes ! I know folk who used Castrol Systrans oils but my experience with aftermarket oils is they react somehow with the metals in the gearbox and get milky hence hard shifts and stripped syncros ! Buy the oil from TPS, just get your chassis number to the till and they should supply you with the right oil- beware they starter selling oil by the paint- only kidding but i was supplied oil in 1/2L bottles from my local TPS, it looked too cheap, only got charged £9 for half a litre !
    FOR SALE:
    Dec 2011
    Wales
    106
    Cheers Chris, good advice as always. If I don't follow that advice and try and save a quid or two by buying inferior or unsuitable oils I'll have to take my chances!!
    Mar 2012
    185
    Dec 2011
    Wales
    106
    That's a handy site for oils Duffy. Thanks
    Mar 2012
    185
    15% off vag spec engine oils at the minute.
    Use the code vag15 at the checkout.
  1. TDI Quattro Gearbox oil Change
    By BlackQuat in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th March 2010, 13:12
  2. Hydraulic oil leak/Audi A6 Quattro/manual/98
    By MADEIRA in forum General Technical / How To
    Last Post: 28th June 2009, 16:32
  3. Replies: 0
    Last Post: 19th June 2007, 16:44
  4. Leaking gearbox oil 2.5TDI with a manual 6 speed gearbox.
    By Joni_s in forum A4/S4 forum(B5 Chassis)
  5. A4 Diesel Quattro gearbox oil
    By QuattroChap in forum Diesel forum
    Last Post: 8th June 2004, 21:17
