JMB RetrofitsVolks Autos
    Nov 2003
    S tAlbans
    70
    Chaning Brake light A4 Avant
    Can anyone advise on how to get to the tail light section to change the bulbs. Everything appears to be enclosed. Before I start pulling the things appart can anyone help?
    Thanks in advance
    simon_golf_tt's Avatar
    May 2004
    Fife, Scotland
    247
    Re: Chaning Brake light A4 Avant
    It's quite simple once you know how. It's not obvious though.
    Open the tailgate. On the inboard side of each tail light you'll see a circular plastic insert about half way up the side of the light. This insert is part of the boot trim plastic. Prise off this insert with a flat bladed screwdriver. Inside you will see a bolt head. Can't remember if it's allen or hex. Anyway loosen this (no need to remove). Once loose the whole light unit will come away from the car (if you pull on it gently). The edge nearest the front of the car (round the side) is held on by two plastic tabs that insert into rubber grommets. The light should pivot here and come away from the grommets.
    Good luck!
    a4sline's Avatar
    Oct 2004
    land of Strongbow
    185
    Yep, 8mm bolt head behind the plug.
    Go gently with the 2 plastic locating lugs as if they break you'll need a new cluster !!!!
    Gently Bentley...just tease it out !!
    Nov 2003
    S tAlbans
    70
    [ QUOTE ]
    [/ QUOTE ]
    Thanks guys I shall be Gently Bentley otherwise there'll make it the most expensive light bulb I'll ever change
