Chris NottAH Fabrications
Thread: Wheel fittment
    Dec 2004
    Ruislip, West London
    25
    Wheel fittment
    Do any of you know if 7.5x18 wheels with an offset of 56 will fit ok on a B6 Audi A4?
    Also is the PCD 5x112?
    Amit
    simon_golf_tt's Avatar
    May 2004
    Fife, Scotland
    247
    Re: Wheel fittment
    7.5x18 is OK
    5*112 is correct
    B6 offsets are usually in the range of 45mm to 30mm depending on rim width.
    56mm would probably need a spacer and longer bolts.
