AH FabricationsChris Nott
Results 1 to 12 of 12
    Aug 2012
    146
    air con pulley replacement
    What do I need to remove in order to replace the pulley on my air con and drive belt? Does the bumper and rads need removing or can I get to it all from under the car?
    Any one have a how to?
    Apr 2012
    lincs
    210
    which engine? they're on different sides / positions.
    2.5 can just about, left sided 1.9 possibly (but haven't tried).
    Have you got the pulley already? I have a nearly new compressor and pulley for a 1.9tdi available.
    cheers
    And
    Aug 2012
    146
    1.9tdi avf quattro.
    Is that bottom left still?
    pauldazzle's Avatar
    Cardiff
    639
    Hi Troopa,
    When we did this on my car. We had the car up on a 2 post ramp, & did it with the compressor off it's mounting but still plugged in & supporting it with a transmission stand.
    A4 Avant B6 1.9 TDI 130 Sport (6) Moro Pearl Blue, GMBH S Line Kit, Decat, 165bhp remap, EGR delete, K&N panel, Dunlop SP Sport Max, Full Leather, Cruise Control, Full DIS, Bose, Audi phone prep, Cooled Glove Box, Rear privacy glass, Rear parking assist.
    2003 Seat Ibiza 1.2 TSI FR in Lima green.
    Aug 2012
    146
    So I can get the belt off and on aswell?
    Did you have 2 pulleys then paul or have I bought your old knackered one lol.
    Apr 2012
    lincs
    210
    Would you believe it the AVF engine is listed with both fitments - if its on passenger side then it's similar to the 2.5 - you might struggle to get the (new) belt past the engine snub mount (but you can remove the snub mount), can you get to the tensioner for adjustment?
    but as above there's enough slack in the pipes to get to the pulley - watch the a/con pipe clips as they're plastic and snap!
    If you find you need a compressor give me a shout - as i can do it for 100 notes delivered (it was £423 two years ago and has had but a few months use - the previous owner tried to fit it to (my) 2.5.
    And
    Aug 2012
    146
    Ok cheers for that. Need to get the belt the weekend.
    Aug 2012
    146
    Tried to fix this today and there is no bolt for the pulley but rather the shaft for the compressor pretuding from the centre. Needless to say i could not remove it, and with my efforts i managed to damage the compressor itself.. grrrrr. so now i need a new compressor. lovely. I miss my honda, so easy to work on.
    Jan 2011
    687
    I got a compressor for mine from an online parts scrap dealer for £126 inc delivery from memory. I didn't even try and replace the pulley.
    2003 A4 Cab 2.4 V6 Manual / 43k miles genuine woohoo (on a 10 year old car lol) / Ebony Black Metallic / Full Grey Leather / Fully Electric Seats / Heated Seats / Interior Light Pack / Cruise / Wood / Bose Symphony II / Black roof
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    634
    Ive still got the rattle.
    Just unsure which route to take now. Either way garage is going to do...
    1. Just replace pulley £150 plus garage fitting.
    2. Buy reconditioned compressor with pulley £200 plus fitting.
    3. Fit pulley myself.
    Iv read that changing compressor other parts are recommended to replace too.
    Archemist! You still have compressor?
    Trooper! Was it a knightmare? Did u remove bumper?
    Best advice guys as this needs to be done while ive got time on my hands,not so much money thou :-(
    A4 avant b6.1.9 avf 6 speed. Bv43 turbo.uprated fmic. More bhp custom map. Powerflow straight through twin pipes. Allard delete kit. Boost,egt, + voltage gauges. Ball,spring boost controller. Fk silversport coilovers. 312mm brake upgrade. B7 multifunc steering wheel. Full dis. Cruise control. Auto locks. Rs4 rear bumper. Full rs4 grills. Drls + hids. 10inch custom sub + amp. Rear parking sensors. Leds everywhere. Parrotkit full speaker streaming. silver 4d carbon interior.never ending...
    Apr 2012
    lincs
    210
    sorry it's now in the hands of the OP!
    hope you get it sorted
    And
    A4 2.5 tdi Q sport '02 AKE, "minor modder", 18x8's S4 Avus , Zender Monza's 18x8.5's, aero wipes, interior trim, dis and cruise, real s4 mirror caps, rns-e led, dble din, VCDS owner-learner - GMBH next
    Aug 2012
    146
    I had a right mare trying to get the pulley off my compressor. Theres no nut it just has the shaft protruding. In the end I bought archemist's compressor but havnt had time to fit it yet.
  1. AIR CON PULLEY ISSUE
    By Leaky Lloyd in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th December 2012, 22:59
  2. Air con pulley
    By troopa in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th December 2012, 22:53
  3. Air con clutch/pulley
    By Ashpotter1991 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th July 2012, 10:28
  4. Air con pulley.
    By DavidW in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th February 2012, 21:45
  5. Urgent Help needed - How to replace air con pump on 2.0 tdi
    By m.lemon in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th July 2010, 22:57
