parts needed for cambelt and water pump ? help
hi mate,i recently did mine and not sure what engine you got but with my 1.9 tdi i replaced the thermostat if its not been done for a while as you got the coolant drained anyway,maybe aux belts if theyre tired maybe?
i did a oil change while i was doing the cambelt change and had the covers off underneath and left it to drain for a bit so if you need a oil change why not do it?
and finally dont forget antifreeze oh and have you got a timing pin kit,you can get them off ebay for a tenner to lock the pump and crank?
cant think of anything else!
thanks mate ok ill get a thermostat as well i has a mini service done a month ago so all levels are all toped up
i think you get a pin with the kit as it states that its everything thats needed
engine is a 1.8t quattro
