EM TuningVolks Autos
    Sep 2009
    95
    Audi a4 b6 avant key fob fault....
    Hi,
    sorry if this has been posted before but for the last month or so I could lock my car after use go to unlock and the fob doesn't work at all place key in ignition unlocks then the key works again until I lock it and come back to it not to work but works after I repeat this procedure ...... Changed the battery is it the fob at fault or a ecu in the car?
    much appreciate if someone could help me out here
    thanks
    sam
    Oct 2009
    Hull
    1,440
    bend the pins out the contact the battery a lot of us have had good results from this including me
  1. AUDI A3 TRANSPONDER FLIP KEY FOB CIRCUIT BOARD REMOVAL
    By DANO80 in forum General Technical / How To
    Last Post: 17th August 2013, 21:30
  2. AUDI A3 TRANSPONDER FLIP KEY FOB CIRCUIT BOARD REMOVAL
    By DANO80 in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th July 2012, 19:55
  3. AUDI 2 BUTTON REMOTE ALARM FLIP KEY FOB
    By fallmonk in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th September 2009, 21:21
  4. How to programme your audi key fob ( Instructions )
    By shawshankuk in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th November 2008, 20:38
  5. Audi S3 Key Fob replacement/spare cost
    By W14FEN in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th September 2007, 18:48
