EM TuningJMB Retrofits
Results 1 to 25 of 25
    Jun 2012
    Teesside
    448
    Just fitted new stalks/steering wheel now fault codes.....
    Hi all finally got round to fitting my 3 spoke leather sline steering wheel, followed the audizine guide for fitting the wheel and airbag and changed wiring plug where i needed too etc, whilst i was on with this i thought i might aswell fit my new cruise and DIS stalks with new highline control module, now ive done all the physical work ie fitting parts and plugging everything in, but as soon as i reconnected my battery and turned on the ignition i now have a flashing brake light on my instruments, also esp light is on and abs light, so ive plugged into vcds, and here are my codes..... (some are unrelated that i know about)
    Monday,11,February,2013,20:05:02:32264
    VCDS Version: Release 11.11.3
    Data version: 20120401
    Chassis Type: 8E - Audi A4 B6/B7
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
    69 75 76 77
    VIN: WAUZZZ8E13A123951 Mileage: 166030km/103166miles
    Address 01: Engine Labels: 038-906-019-AVF.lbl
    Part No: 038 906 019 JQ
    Component: 1,9l R4 EDC 0000SG 1570
    Coding: 00002
    Shop #: WSC 63351
    VCID: 6FE7CD652D862D1
    WAUZZZ8E13A123951 AUZ6Z0B0164657
    No fault code found.
    Readiness: 0 0 X X X
    Address 03: ABS Brakes Labels: 8E0-614-517.lbl
    Part No: 8E0 614 517
    Component: ABS/ESP front 1726
    Coding: 00000
    Shop #: WSC 00000
    VCID: E5CB2F4D7F7A671
    2 Faults Found:
    01044 - Control Module Incorrectly Coded
    35-00 - -
    00778 - Steering Angle Sensor (G85)
    66-10 - Not Matched - Intermittent
    Address 08: Auto HVAC Labels: 8E0-820-043.lbl
    Part No: 8E0 820 043 H
    Component: A4 Klimaautomat 1016
    Coding: 00000
    Shop #: WSC 63351
    VCID: 2649E841C2FC2C9
    2 Faults Found:
    00819 - High Pressure Sensor (G65)
    07-10 - Signal too Low - Intermittent
    01317 - Control Module in Instrument Cluster (J285)
    79-00 - Please Check Fault Codes
    Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
    Part No: 8E0 907 279 C
    Component: int. Lastmodul RDW 0203
    Coding: 00001
    Shop #: WSC 63351
    VCID: 32610411FE34409
    1 Fault Found:
    00532 - Supply Voltage B+
    53-10 - Supply Voltage Too Low - Intermittent
    Address 15: Airbags Labels: 8E0-959-655-84.lbl
    Part No: 8E0 959 655 B
    Component: Airbag 8.4EP 2000
    Coding: 0010602
    Shop #: WSC 63351 000 00000
    VCID: 36693801425C5C9
    1 Fault Found:
    00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
    001 - Upper Limit Exceeded - MIL ON
    Address 16: Steering wheel Labels: 8E0-953-549.lbl
    Part No: 8E0 953 549 Q
    Component: Lenksáulenmodul 0601
    Coding: 01042
    Shop #: WSC 06325
    VCID: 41835BDD4B92EB1
    5 Faults Found:
    01330 - Central Control Module for Central Convenience (J393)
    49-10 - No Communications - Intermittent
    01333 - Door Control Module; Rear Left (J388)
    01331 - Door Control Module; Driver Side (J386)
    01794 - Control Module - Incorrect Chassis (VIN) Number
    35-00 - -
    Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
    Part No: 8E0 920 950 J
    Component: KOMBI+WEGFAHRS. RB4 D35
    Coding: 00400
    Shop #: WSC 10001
    VCID: 30650E19F038729
    2 Faults Found:
    00779 - Outside Air Temp Sensor (G17)
    30-00 - Open or Short to Plus
    Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
    Part No: 8E0 951 177
    Component: Innenraumueberw. 0604
    Coding: 00001
    Shop #: WSC 00000
    VCID: EBDF5975999E511
    1 Fault Found:
    01463 - Alarm triggered by Sensor for anti-theft alarm System
    43-00 - Closed
    Address 46: Central Conv. Labels: 8E0-959-433-MIN.lbl
    Part No: 8E0 959 433 BD
    Component: Komfortgerát TBF 1110
    Coding: 06859
    Shop #: WSC 63351
    VCID: 74EDC20944A00E9
    Subsystem 1 - Part No: 8E2959802B
    Component: Tõrsteuer.FS BRM 0002
    Subsystem 2 - Part No: 8E2959801B
    Component: Tõrsteuer.BF BRM 0002
    9 Faults Found:
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    01561 - Left Rear Door
    59-10 - Can't Unlock - Intermittent
    61-00 - Won't De-Safe
    01562 - Right Rear Door
    01801 - Door Warning Lamp; Drivers Side (W30)
    57-10 - Electric Circuit Failure - Intermittent
    01811 - Supply Voltage for Door Controller; Drivers Side (J386)
    37-10 - Faulty - Intermittent
    01802 - Door Warning Lamp; Pass Side (W36)
    Address 56: Radio Labels: 8E0-035-1xx-56.lbl
    Part No: 8E0 035 186 L
    Component: concert II GRO 0001
    Coding: 01001
    Shop #: WSC 63351
    2 Faults Found:
    00852 - Loudspeaker(s); Front
    36-00 - Open Circuit
    00858 - Connection; Radio ZF Output to Antenna Amplifier
    So ignore the ones related to rear doors and door electrics as that is a work in progress, but the ones im worried about are the ones related to the control module incorrect vin etc etc.....
    Any thoughts?
    Mods done: interior: Light to dark conversion, To Do: Carbon trim, carpet to be replaced, rear window retrofit. Exterior: Resprayed in Skoda's Rallye Green, 18" RS4 reps fitted, xenons, LED sidelights/NumberPlate lights, B Pillars wrapped in carbon. To Do: Lowering 35mm all round, tints, Tuning: Yet to do exhaust/remap/ egr delete etc..
    Oct 2009
    Hull
    1,437
    you need to code them to the car if you havent already
    follow this from top to bottom read everything first then set about coding it all up
    http://dl.dropbox.com/u/8970502/VAG-...ctivation.html
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,430
    look on the wiki it will guide you through
    Jun 2012
    Teesside
    448
    cheers guys got the lights out now im just coding the dis/cruise, only thing im stuck with is the instrument adaptation im unsure what options to select? does it matter?
    Oct 2009
    Hull
    1,437
    yes it does matter
    I think you will want 31000 theres only one way to find out lol
    Jun 2012
    Teesside
    448
    Well i got working DIS and cruise, my new steering wheel is one notch off but ill soon adjust that, only thing is i must of input an incorrect figure when coding, as i took the car for a quick drive, and the esp kicked in 3 times just cruising along no ice, nothing, just short pulses of what felt like the abs kicking back. After the third the light came on and stayed on,
    Dont know if any of my car details will help but its a 2002 se tdi awx 5 speed, had no extras from factory, i put the 'Q' scsm in and also the matching slipring,
    Oh and i dont think i selected 31000, my car was 30100 as standard
    Oct 2009
    Hull
    1,437
    I think you would have needed a highline steering module to have 30100
    Jun 2012
    Teesside
    448
    I have a highline one mate, 8E0-953-549-Q this is the part i just fitted, the old one was F
    Apr 2012
    lincs
    210
    Dan's definitely got the highline module (i know his dealer)
    Dan there should be a code for the abs brakes - did you scan before you changed modules - what code was in before?
    if not use the 'flyer' on VCDS to guide you - it should be something like 004455 (that's mine 312 discs / abs etc) - it's a soft code so you've lost the 'original' but you'll have it on the scan / can work it out.
    cheers
    And
    Jun 2012
    Teesside
    448
    I didnt scan before changing it over mate, i used the calculator which was linked from one of the other forums, i took a 3 digit code from the sticker in spare wheel well, ill have to have a proper look tomorrow, mine only has small brakes, car apparently originally came with 15" wheels, was a basic SE,
    the calculator i looked at referred to this off rosstech
    0?xxx: Chassis
    • 9 = Audi A4
    0x?xx: Brakes
    • 2 = Brembo 17" (PR-1LJ)
    • 3 = FN3 16" (PR-1LT/1LF)
    • 4 = HP2 16" (PR-1LX)
    • 4 = FNR 16" (PR-1LA/1LG)
    • 5 = FN3 15" (PR-1LB/1LE)
    • 6 = C54 (PR-1LZ)
    0xx?x: Engine
    • 5 = 4/6 Cyl. Diesel
    • 7 = 4/5 Cyl. Gasoline
    • 9 = 6/8 Cyl. Gasoline
    0xxx?: Transmission
    • 5 = Manual
    • 7 = Automatic (5HP19, 5HP24, AG4, AG5)
    • 9 = Multitronic (01J, CVT)
    To which i think i missed the 9 for chassis i think i left that as 0 so that might be my mistake ill recode it in the morning,
    Im guessing my code should be 09555?
    Oct 2009
    Hull
    1,437
    I know he has the highline module now but he is saying he had 30100 on the old module which was not highline yet that code is for higline modules according to the guide I linked to above
    09555 sounds right to me it sounds like you have the same as me mine had 15 inch wheels from stock
    Apr 2012
    lincs
    210
    yep when you run the ABS coding module it'll bring up the 'flyout' with the codes on it.
    yours will be something like 04575
    although ross-tech would tell you it's 09555 - my ABS code was always 04xxx.
    "stu-m" sorry i was only joking as i supplied the module!
    And
    Jun 2012
    Teesside
    448
    Could this simple mistake cause my ESP issue?
    Ill get on with re-coding it in the morning and update once i have done it and take it for another test
    Oct 2009
    Hull
    1,437
    Quote Originally Posted by archemist View Post
    Yeah I know you was I was referring to his old module and coding
    Apr 2012
    lincs
    210
    Dan
    have a look at the ross-tech wicki:
    Audi A4 (8E) Brake Electronics (Bosch 5.7) - Ross-Tech Wiki
    your ABS coding should be 04xxxx NOT 09xxxx (that's the log-in code)
    so 04255 or 04155 - double check your PR code for the brakes m8 (2nd line of the options codes on the sticker - mines "1LT")
    hope it helps
    And
    Jun 2012
    Teesside
    448
    From what i can gather on this web link Audi A4 (8E) Brake Electronics (Bosch 5.7) - Ross-Tech Wiki
    My login code is 09555 and my coding code is 04255
    Ill try to recode with these numbers in the morning and hopefully this will correct my ESP issue, but overall im happy with the job the new wheel looks the BIZ, shame i snapped one of the shroud screws, so the wheel rubs slightly, on my test drive i tested cruise, functioned well, and my DIS i think i activated more functions than i needed (as i guessed the code really)
    Will update the thread tomorrow,
    thanks for the help guys
    Jun 2012
    Teesside
    448
    Re: Just fitted new stalks/steering wheel now fault codes.....
    Oh on one other note my horn isnt working :-S
    Jun 2012
    Teesside
    448
    right so i now have the abs/esp coded correctly, no lights or faults,
    my only issues now are my steering wheel is constantly showing:
    01044 - Control Module Incorrectly Coded,
    which i am confused about as i have selected the correct code for my wheel
    Coding
    • 0?xxx: Steering Wheel
      • 0 = Standard (without Multifunction)
      • 1 = 3-Spoke Steering Wheel (Sport Steering Wheel)
      • 2 = Multifunction Steering Wheel with Radio Control
      • 3 = Multifunction Steering Wheel with Radio/Telephone Control
      • 4 = Multifunction Steering Wheel with Radio/Telephone/Voice Control
      • 5 = Multifunction Steering Wheel with Radio/Voice Control
    • 0x?xx: Options
      • +1 = Tiptronic
    • 0xx?x: Board Computer & Cruise Control
      • 0 = Board Computer & Cruise Control not installed
      • 1 = Board Computer installed
      • 2 = Cruise Control installed
      • 4 = Board Computer & Cruise Control installed
    • 0xxx?: Rear Wiper (Chassis)
      • 1 = Rear Wiper not installed (Sedan/Cabriolet)
      • 2 = Rear Wiper installed (Avant)
    My wheel is not a standard wheel, and is 3 spoke (not MFSW) so surely my code of 01041 should be correct? i have then gone into adaptation and opened block 081, and entered 00111 so that the module can learn the vin etc, but still get this fault,
    that and the fact my horn doesnt function at all :S
    Starting to wonder if it is because i have fitted an a3 steering wheel ( well i assume its an a3 one as part number starts 8p0)
    Apr 2012
    lincs
    210
    Dan
    My 3 spoke wheel was coded 00002 originally - but it now works with either the 01042 or 00042 (avant) code - i think the wheel is 'dumb' unless it's multi-function- there's no airbag faults and the horn works.
    If you've a multi-meter check the horn pins 'short' when pressed.
    By the way why did you change the slip ring? is it a b6 or b7 one?
    Is it possible the A3 horn wiring is different?
    Oh and have you cleared the fault codes and driven it for a bit?
    And
    Jun 2012
    Teesside
    448
    Ive cleared the codes mate but it comes back with control module incorrectly coded, and yeah i changed the slipring for a b7 one, so all plugs line up and fit right, i changed the 4 pin plug for the airbag (i read all the warnings about single stage dual stage etc) so you reckon it might be worth coding it to think its multi-function? i dont own a multi meter mate,
    Only driving ive done is the school run this morning... about 15 miles no difference to horn
    This is the wheel i fitted:
    AUDI A3 S3 A4 S4 A5 S5 A6 S6 A8 Q5 Q7 TT S-LINE STEERING WHEEL with airbag | eBay
    Apr 2012
    lincs
    210
    dan
    it's possible, though unlikely the horn 'switch' is at fault (for horn problem)
    have you seen the pin-outs in this post
    B7 Multi-Function Steering Wheel into 2002 Audi 24...
    is that what you did?
    but you've gone beyond me already....(stuck in b6 land!)
    might be worth a pm to NHN?
    And
    Jun 2012
    Teesside
    448
    The airbag wiring harness i got might be slightly different, ill take it back out and cross reference the pin locations on that diagram to the one i have and HOPEFULLY it will be something obvious
    Apr 2012
    lincs
    210
    dan
    have you checked the fuse? (horn one)
    did you do the whole re-calib sequence when you did your abs as the wicki guide - there's a thread about a guy who had this prob on a rs6 - think it might be similar
    Strange fault code, 01044
    And
    Jun 2012
    Teesside
    448
    Well i still have that fault code, BUT.... i got my horn working, so that was unrelated, the multi plug was layed out differently to the one in the guide pics, for some reason my horn pins were on the upper row on their own, there were two blanks on the lower so swapped them into them and viola! horn working as it should, all the info on that link seems to point to recoding abs module, but i dont have any lights or anything so im not sure how that could be at fault.....however as id prefer no faults i will attempt recoding it as it may be because ive recoded instruments/steering wheel afterwards,
    Apr 2012
    lincs
    210
    SCCM and ABS are related i just don't know how!
    i'd try and follow the steering calib / module / abs sequence again
    nearly there now
  1. just fitted coilovers.and the wheels wont go on :(
    By petrol~head in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st July 2009, 09:24
  2. Just got new genuine porsche wheels what else do i need
    By danotto in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th July 2008, 12:14
  3. New S3 Steering wheel on old S3 ??
    By S£ in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th March 2008, 15:24
  4. retro fit multi function steering wheel a3
    By wilkinson1 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th November 2007, 10:34
  5. Retro Fitting Multi Function Steering Wheel?
    By Von Maximo in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th April 2007, 18:30
