Volks AutosAH Fabrications
    Jan 2013
    Nottingham, United Kingdom, United Kingdom
    29
    Elm light, and bad misfire! Help!!
    Just driving about, and the eml light started flashing, with a bad misfire.. I had put fuel in two miles prior (which I guarantee was correct fuel, but may be dodgy?)
    i plugged in vcds hoping to find a coil or something, but all that is there is
    p17550 load calculation cross check, lower Limmit exceeded
    p1142-002 lower limit exceeded - intermittent
    the car is a 3.0 v6 2003 a4 cab
    any help would be much appreciated, as I'm not sure where to start with that fault code!
    Very upset!
    Jan 2013
    29
    Sorted! Got some time to mess about with vagcom and found it to be cylinder 6 coil, went into measuring blocks and found cylinder 6 doing nothing at all, constant misfire!
  1. Engine Management Light and Misfire - 2004 1.8T
    By dalespitfire in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th June 2010, 12:48
  2. Engine Mgt Light and Trac Control lights on - HELP!!!!
    By razza1 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 24th March 2010, 08:55
  3. Traction control light and fan please help?!!!!!!!!!!
    By a3-se in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th November 2009, 22:25
  4. Retro fit Lights and cruise control HELP PLEASE
    By fin in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th October 2007, 13:22
  5. Flickering Lights and Alarm - HELP
    By Gavin Cooper in forum VCDS (formerly VAG-COM) forum
    Last Post: 17th September 2006, 17:31
