Sky InsuranceAH Fabrications
    Mar 2008
    1,040
    good place to pick up a live from
    need a ign live anyone got a good place to pick up form ?????audi a4 cab
    Feb 2012
    Glasgow
    219
    Re: good place to pick up a live from
    Might want to give a bit more info about what you need it for and where. Obvious place is thr fuse box but there might be somewhere more convenient with more details!
    Mar 2008
    1,040
    im wanting to wire a 12v convertor to power up my ps2 ... i wanna know if i could join to the power of my rns-e so when i leave the key in ign it stays on .. pull key out it gose off .. the same as my head unit ..... witch wire do i need to join to ?
    Jun 2003
    World of my own
    9,813
    If you have a proper accessory feed at the head unit then this is the best place to pick it up (B6 vehicles don't have it as they use the CANBUS, but your cabriolet maybe different). Pull the HU and you will have a black power ISO connector. It will have a brown earth, red with white stripe permanent live, and hopefully 3 pins along from the earth you will have a yellow with red stripe wire, this is the accessory feed (ignition on which stays live until you pull the keys out). You can use this to trigger a relay that then feeds the PS2. I wouldn't wire the PS2 directly to it. It needs a relay.
    Alex Turner
  1. Good place to get 2nd hand crankshafts from?
    By Andrew@A.L.D in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd December 2009, 21:56
  2. Cheapest place to pick up new rear shocks Ta
    By redevo1 in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st October 2008, 15:51
  3. Good place to buy a battery?
    By Macduff in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th December 2007, 10:07
  4. A4 Quattro Turbo - Poorly...Need a good place to get it fixed
    By tobybutler in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th November 2007, 00:21
  5. Any good places to install an amplifier?
    By jrleech in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th May 2006, 20:32
