AH FabricationsEM Tuning
Thread: airbag light on
    Apr 2011
    160
    airbag light on
    Run a check on it.
    Comes back with 01221 crash sensor side airbag
    . 011 open circuit. Drivers side
    Anyone up to speed with these not that great with electrics on cars.
    Where is this sensor situated on the car.
    Im guessing open curcuit is its not connected in some way.
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,413
    Just check the seat harness plugs.
    If you have recently slide the seat all the way back it may have a loose connection and this is a common issue on most VAG cars.
    Once done clear the fault and do a recheck of the system
    Mike
    Apr 2011
    160
    Yea tried them nothing changed. Where is the crash sensor for the side airbags.
    Oct 2012
    Wigan
    178
    it is the door piller the one between the rear and front door, you have to put your set right forward, remove the bottom seat belt and trim and it is in there,,, I still have the problem
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    534
    Ive got airbag light on too.
    Driving home tonight and all fault lights started flashing and speedometer wouldnt work! all this @80mph.
    Besides lights flashing and speedo not working it drove fine.
    Got home,switched off and back on,all ok???
    Done some checks and got 4 faults all relating to air bag...
    018057
    01738
    01217
    65535
    1.9 avf 6 speed. Bv43 turbo. Swifttuning custom map. Powerflow straight through twin pipes. Allard delete kit. Boost,egt, + voltage gauges. Ball,spring boost controller. Fk silversport coilovers. 312mm brake upgrade. B7 multifunc steering wheel. Full dis. Cruise control. Auto locks. Rs4 rear bumper. Full rs4 grills. Drls + hids. 10inch custom sub + amp. Leds everywhere. Parrotkit full speaker streaming. silver 4d carbon interior.never ending...
  1. A6 tdi airbag light on! looking at purchasing car?
    By evomaster3000 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 8th January 2005, 21:57
  2. Passenger Airbag Light
    By steveh in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st December 2004, 14:29
  3. abs airbag light
    By mlcadman in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th October 2004, 18:46
  4. Airbag Light
    By ajmackie in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th March 2004, 16:18
  5. Horn / Airbag light problem
    By MikeS in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th February 2004, 17:46
