EM TuningAH Fabrications
Results 1 to 9 of 9
    Feb 2013
    Newcastle
    43
    1.9tdi 115 engine to replace a 1.9tdi 130 engine?
    Well my Audi a4 b6 started making a clunking sound, it then got louder and think i diagnosed the problem as the big end bearings have gone, Ive found an engine for £250 with 102k with everything still attached, But its the 115bhp engine, what will i need to swap around so its back to the 130? Thanks jay.
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,537
    I would use ETKA to compare the parts and see what is different, otherwise could not say myself
    Mike
    B6 A4 1.9 TDI Sport 130 - GMBH/S-Line kit - Akoya Silver
    - BUILD THREAD >>
    Jul 2007
    London
    3,211
    What car is the engine from ? There are a few differences in the way the block is cast hence if off a transverse engine it will need a few holes drilled and taped so you can fit engine mounts and aditional brackets. Also the cambelt kit is different between early Pd engines and late pd engines, more so between transverse and longitudinal !
    Injectors, rods, turbo are different between the 2 power ratings so it's not that simple as it looks ! Good price though for the engine, sold pd115 for over 400 quid before but i left all ancilarries on so a few quid can be recovered from the sale of these extra bits ! Hope this helps !
    Ps: I am breaking a b5 audi a4 with a pd engine, starts on the button and it's done 105k...
    FOR SALE:
    Feb 2013
    Newcastle
    43
    The donour car is a audi a4 b6 avant on a 2002 plate and mines the saloon a4 b6 also on a 2002 plate. Cheers
    Oct 2009
    Hull
    1,437
    whats the engine codes of both?
    Jul 2007
    London
    3,211
    The b6 never got a pd115, they either had 100Bhp AVB or 130 bhp AWX/AVF engines. A pd 115 was fitted on the early audi a4 b7 untill 2007...
    FOR SALE:
    Oct 2009
    Hull
    1,437
    Quote Originally Posted by adamss24 View Post
    that was my next thing!!
    Sep 2007
    20
    Yes it did. The very last of the B6 Avants did. I own one.
    Nov 04 1.9 TDI Avant. 5 Speed Manual. 115 Sport. Engine Code BKE.
    Feb 2013
    Newcastle
    43
    I got the licence plate number of the bloke and it turns out it was the 130bhp awx same as mine, happy days
  1. Ideas for uprating a '00 1.9TDi (115)
    By MuddyPlanter in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th November 2011, 20:18
  2. Engine mount replacement..how much? also odd oil leak
    By deanski in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st October 2011, 21:34
  3. 1.9tdi 115 service intervals
    By dieselfitter251 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 30th December 2010, 17:56
  4. Is it worth placing an 1.9tdi 115/130 tuning box on e-bay?
    By Niknak in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th May 2010, 20:53
  5. Engine Mount replacement
    By RichA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd December 2005, 23:15
