Sky InsuranceJMB Retrofits
    Mar 2004
    Leicester UK
    133
    Boot wiring diagram
    Hi has anyone got a link or a picture of the wiring loom to the boot, want to check the wiring to the boot handle as it dont work!
    So many threads with different ideas of what could be the problem, most likely it seems to be a broken wire on the left hand side when you open the boot.
    Also looking for options on how or where to check it out.
    I take it if my fob opens the car then the boot should work with the fob or are they programmed differently. Would I be able to see a signal on the wiring if I press the button on the fob to open the boot?
    Car is a 2004 TDI sport 130 saloon B6.
    AudidriverA4's Avatar
    Sep 2012
    180
    Hi
    I had a broken wire in mine,
    just as you open the boot...look at the black rubber plastic pipe that contains the wires on the left side, pull out the rubber parts of the solid plastic part check the wires there, it was a thick brown wire that broke if I remember correctly....
    that's where mine broke.
    Mar 2004
    Leicester UK
    133
    Quote Originally Posted by AudidriverA4 View Post
    Hi
    How did you check if it was broke?
    Sep 2012
    180
    When I pulled out the wires I could see where the wire had broken ...
    Easy fix then
    I might have some photos of the time I fixed my one ...I'll have a look tomorrow for you.
    If it makes it a bit clearer.
    Mar 2004
    Leicester UK
    133
    Easy fix then
    Did you manage to find your pictures?
  1. Replies: 0
    Last Post: 7th November 2010, 17:21
  2. Wiring diagram for an S3 (02)
    By Mattytay in forum General Technical / How To
    Last Post: 1st March 2005, 20:40
  3. Alarm/Door connector wiring diagram?
    By Markb in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd February 2005, 22:14
  4. audi 100 wiring diagram
    By imported_my_audi_is_brok in forum Classic Audi Forum
    Last Post: 30th January 2005, 17:04
  5. wireing diagram
    By lenin in forum General Technical / How To
    Last Post: 14th September 2004, 17:51
