AH FabricationsJMB Retrofits
    Dec 2012
    Northants
    217
    Replacing the standard amp and sub
    Is ist possible to remove the amp and sub but use the wiring to power an aftermarket amp and subwoofer ??? I have a 12 inch sub in a box with the amp fixed to the back if the box, just wondering if I can tap into the existing wiring to power it.
    If it's got tits or gears it's gonna be expensive.
    Jun 2003
    World of my own
    9,813
    You can't power the new amp from the existing loom (it's only 5-10amp), so you will have to run a 40+ amp cable back to the battery, but all the other feeds are there - left & right rear pre-outs and remote on. Also with the non Bose system the stock amp drives the rear speakers as well as the stock sub so you need to keep it wired in or replace it.
    A4 Avant (B6) Stealth sub install
    Alex Turner
    Dec 2012
    Northants
    217
    Thanks Andy, I fitted the stereo today and the iso lead, tbh it sounds like the whole lot wants completly ripping out and starting from scratch!!! The fronts are MEGA loud and the rears REAL quiet, just cant seem to find a happy medium using the fader on the head unit, sounds very harsh...
    Jun 2003
    World of my own
    9,813
    The fronts will be louder than the rears as they are running off the HU which will now be delivering 2 x 50w+ while the rears are still using the feeble Audi/Nokia amp which is 2 x 20w. You need to replace the fronts with some decent components - JL Audio TR650csi's are decent and fit a sub, then ideally run the fronts and sub off a 4ch amp, and rewire the rears to the HU for when you have rear passengers. Makes a world of difference
    You can then ditch the ISO harness adapter and run proper RCA's
    Alex Turner
    Dec 2012
    Northants
    217
    Fancy a nice little earner if I get everything I need???
  1. Amp and Sub Installation
    By TDIQ in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th October 2009, 20:11
  2. how you connect yor amp and subs to ur batt.
    By stevie_g in forum In-Car Entertainment
    Last Post: 25th February 2009, 20:18
  3. New wheels or keep the standard wheels and drop it?
    By Bong Water in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th January 2008, 23:27
  4. Howto wire amp and sub speaker on Audi A3?
    By beqen in forum In-Car Entertainment
    Last Post: 7th April 2007, 15:37
  5. Audi amp and sub
    By S4_dan in forum In-Car Entertainment
    Last Post: 28th March 2006, 22:42
