Results 1 to 10 of 10
    Feb 2013
    A4 2.0 Fsi avant. front and rear bumper question! please help! NEWBIE!!
    hi guys.
    i know this question has been asked a lot over this forum, but i still havent found the answer i've been looking for.
    Basically i bought myself a 2.0 Fsi avant (estate) it has the standard painted front and rear bumpers on it. both have paint peeling off them which is not good.i thought this would be the perfect opportunity to replace them with the bumpers i really want. the GMBH kit.
    my question is, would a GMBH front bumper from a saloon fit straight onto my avant estate? i have heard on some places that the avant and s-line front bumpers are slightly different? (correct me if i'm wrong.)
    and...if i buy the rear lower part of the bumper from TPS or a dealer, will that fit straight onto my existing upper half of my rear bumper? i only have a single exhaust and i'm not sure if there is a GMBH rear bumper that has a single exhaust cut out?
    ANY help would be greatly appreciated.
    Dan!!
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,689
    Have you read the Bumper Options sticky?
    Front bumpers are the same between saloon and avant, it's only the rears that are model specific. A complete Gmbh front (upper and lower) will fit straight onto your car, a Gmbh lower will fit, but the existing upper will need some trimming.
    As long as you buy the avant lower from TPS with the twin cutouts then it will be a straight swap for your existing rear lower.
    Feb 2013
    Huddersfield
    I have a 1.9 TDi Quattro on a 04 plate with the S-Line kit. Is the rear diffuser removeable\interchangeable? I'm after a twin exhaust conversion and was wondering if it would be possible to just change the rear diffuser as supposed to the whole bumper.
    Thanks in advance....
    Feb 2013
    thanks very much pal. thats helped me out LOADS!!! really appreciate it!
    Mar 2008
    Dorset
    13,689
    Quote Originally Posted by nazkhan33 View Post
    Yes, as long as you buy an avant specific rear lower. All the part numbers are in the sticky.
    Q4
    Oct 2008
    33
    Hi Dan,
    I beleive you can get a single exhaust cut out GMBH rear lower valance for the avant. Try this part number 8E9-807-521-F-GRU
    Hope that helps.
    Feb 2013
    Quote Originally Posted by Q4 View Post
    Hi Dan,
    Hope that helps.
    i dont suppose you know if this is for the estate is it? but thanks very much for the reply mate. many thanks!
    Q4
    Oct 2008
    33
    Yep its for the avant, the first part (8E9) denotes avant, (8E0) denotes saloon. The (F) part is single cut out for exhaust.
    so 8E9-807-521-F-GRU = Avant one cut out
    8E9-807-521-G-GRU = Avant two cut outs
    8E9-807-521-H-GRU = Avant no cut outs.
    They all should come with the black sticker part. Been researching this very thing myself recently.
    Feb 2013
    i've located a complete front bumper from a saloon. with grills and fog lights, the guy wants £270 collected? is that expensive? seems it!
    Mar 2008
    Dorset
    13,689
    Front centre is £80 plus, side grilles are £20 ish each, lower would be £100-150 new from TPS. Plus painting. If it was the right colour I'd go for it, if not then it's a matter for you but it's not that bad.
  1. Allroad bumper onto pre facelift a6 avant front and rear ??
    By andybnwc in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 25th January 2013, 18:53
  2. Anyone got front and rear 4rings badges please?
    By crazypainter in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th October 2010, 21:12
  3. Front and rear bumpers
    By cabriolet in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th December 2009, 17:29
  4. S3 front and rear bumpers
    By Staz in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd September 2008, 12:43
  5. How do i remove the front and rear bumpers
    By BromleyA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th January 2005, 16:37
Tags for this Thread
