Chris NottMonster Motorsport
    Dec 2012
    help needed be4 i give up
    Right ive just fit a replacement engine to my 1.8T as the original give up
    I fit a New waterpump and timing belt kit
    also cleared out the breather system fitting a new elbow as original was broke
    The car starts and ticks over fine and also revs without issue and when took for test drive along my street for around 30-40 yards car seems to boost fine ( wont test drive any further until problems are rectified )
    The 2 problems
    1. The water system will not bleed
    2. Oil light/sign comes on dash cluster when revving the car
    Somebody please help me before i either give up and break the car or sell as it is
    AlexGSi2000's Avatar
    Feb 2012
    Liverpool
    1,068
    Did you change the thermostat? - all coolant pipes plumbed in correctly?
    - Oil light I think would refer to oil pressure, did you check the oil pickup on the new engine?
    Dec 2012
    I ve tried both thermostat's from both engines and all pipes plumbed correctly ( will be buying new thermosat to eliminate problem)
    I never checked Oil pick up on new engine no is there an easy way to check this or is it a matter of removing sump
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,930
    sump off to check
    and while its off just replace the pick up pipe
    how many miles has the engine got on it ?
    Dec 2012
    engine as 85k and running fine before removal and the reason i never thought about swapping the pick up over
    does the subframe need removing for sump removal
    Also is there any other possible reasons for oil light whats the common problems (also nothing on diagnostics check)
    I'm new to these engines all help is grateful
  1. Help needed again.
    By Stuart_A3_Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th July 2003, 22:12
  2. Urgent help needed
    Last Post: 13th July 2003, 09:02
  3. Help...need to order
    By Drystone in forum Detailing
    Last Post: 4th June 2003, 23:39
  4. Replies: 0
    Last Post: 1st March 2003, 19:50
  5. Help! Need a new coilpack!
    By SteveS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd January 2003, 22:29
