AH FabricationsChris Nott
    Jan 2013
    6
    6 stack cd player in glovebox problems
    My CD player stopped working the other day, it sounds like it is a mechanical fault. Disc 4 is trying to get ejected and it just keeps trying to eject, but nothing happens. I tried to eject some of the other discs to see whether there was just a problem with disc 4 but was met with the same symptoms. Eventually there is an error on the cd player and the process stops.
    Has anyone else had similar problems? and how easy are these cd players to remove? i noticed two slots at the bottom and wondered if they are used to remove the 6 stack...
    thanks
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,538
    Quote Originally Posted by mrstruan View Post
    You need two VAG audio removal tools (you can get them from Halfrauds), slide them into the slots until you feel the catches release and then the CD changer will just pull out.
    It sounds like one of the CDs has jammed, is it a copy (they are often thicker and/or have a sticky label)?
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
  1. glovebox problems
    By Rcpvin in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th May 2014, 08:04
  2. glovebox problem
    By Jonny 2.0T in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th January 2012, 11:36
  3. Symphony CD Player/changer "error2" problems?
    By TonyA3 in forum In-Car Entertainment
    Last Post: 13th November 2011, 15:34
  4. B6 Glovebox problem
    By Dubbers1 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th July 2011, 09:07
  5. Glovebox latch problem
    By AndyMac in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th August 2006, 18:17
