Monster MotorsportEM Tuning
Results 1 to 11 of 11
    Jan 2013
    Nottingham, United Kingdom, United Kingdom
    29
    headlight lens hazy! can these be fixed?
    my headlamps are quite hazy on the front lenses, what is best to do? can they be brought up nice, or is it simply new headlamps? it looks like a layer on the lens has actually melted away, i do have some spare lamps in the same condition, which i will probably have a practice on first, maybe wet sand it down and polish it and see if it comes up?
    was just wondering if anyone else has had this issue, as i have seen a few on the road that are the same!
    Oct 2012
    487
    Have a look on ebay i got a two stage cut and polish for plastic lenses about £10 worked well on my passat
    GeoffDunk's Avatar
    Jul 2012
    Norwich
    438
    I had mine clay barred by a proffesional when he detailed my car. both from and rear lenses were perfect once he had finished with them.
    Jan 2013
    29
    okie doke, i work for a main dealer with a very good valet bay, which has all the goodies i need! will have a play with one of my spare lamps tomorrow, and will update how it goes on here!
    4th set of a wheels in a year
    Jul 2012
    merthyr, south wales
    425
    Visit krisavant's Instagram Channel
    If your brave enough, 2000 grit wet & dry, compound machine polish then final stage polish with soft pad.
    They will look brand new.
    AlexGSi2000's Avatar
    Feb 2012
    Liverpool
    1,068
    I tried wet and dry along with polishing on my headlights, but it seemed the actual plastic had started to turn a yellowish colour over 120,000 miles.
    I ended up replacing the units for some "Depo" ones which were purchased for £45/ea on ebay - they have been on the car for about 6 months now and are perfect, really freshened up the front end!
    Dec 2012
    Hampshire
    137
    Toothpaste works as well!
    Dolphin Grey B6 A4 Avant 1.9tdi
    Mods so far: Allard EGR delete pipe, Shark remap, Bilstein B12 Sportline suspension
    Jan 2013
    29
    i have bought this in the end, which with machine polish has worked very well...
    Turtle Wax Headlight Restorer Renovator Kit Repairs Dull & Yellow Lenses FG6690 | eBay
    dpbayly's Avatar
    Oct 2012
    Royston, Herts
    366
    I carried out the sanding and polishing method on a few of my previous cars and it really dose work well including restoring the yellowing.
    Here's a few of the past results:
    Mitsubishi FTO
    Before (de-laminating and yellowing)
    After (like new)
    My 540I (had bad motorway stone chips)
    before
    after
    some of the in between process
    wet flatted back (start with 600 then 800 then 1000 then 1500)
    after all the flatting they looked like this
    once you have them looking like this i used a mop (machine polisher) but the same effect can be had by hand just takes elbow grease along with a cutting compound.
    Jan 2013
    29
    That's amazing, great post! Cheers mate... Gonna get on mine again tomorrow, hopefully get them as nice as yours!
    dpbayly's Avatar
    Oct 2012
    Royston, Herts
    366
    No worries,
    Get the worst off with wet 600 once you have it nice and smooth then work at it with wet finer stuff till it looks like my last pic before I polished then its just compound and elbow grease till it looks mint, with the wet n dry paper add a bit a fairy liquid to the water helps let the paper slide over the lens and stops the paper clogging.
  1. Can I remove the headlight lens?
    By TURBOTRONICS in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd February 2010, 20:13
  2. headlight lens can it be replaced????
    By khalil in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th May 2008, 21:15
  3. Headlight lens removal A3?
    By Clach in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th August 2007, 21:48
  4. Can this be fixed?
    By Defratos in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th October 2005, 06:10
